Salta al contenuto principale
ACER Aspire 7750G-6645 Fan Replacement
Cosa ti serve
  1. ACER Aspire 7750G-6645 Fan Replacement, Keyboard: passo 1, immagine 1 di 2 ACER Aspire 7750G-6645 Fan Replacement, Keyboard: passo 1, immagine 2 di 2
    • Turn off the laptop, and open the lid.
    • Separate the first two layers by prying them apart, using a spudger.
  2. ACER Aspire 7750G-6645 Fan Replacement: passo 2, immagine 1 di 3 ACER Aspire 7750G-6645 Fan Replacement: passo 2, immagine 2 di 3 ACER Aspire 7750G-6645 Fan Replacement: passo 2, immagine 3 di 3
    • Lift the keyboard, so that its ribbon is visible.
    • Remove the ribbon from the board by using a small metal spudger or flathead screwdriver. (if needed)
  3. ACER Aspire 7750G-6645 Fan Replacement, Fan: passo 3, immagine 1 di 2 ACER Aspire 7750G-6645 Fan Replacement, Fan: passo 3, immagine 2 di 2
    • Remove the two 3mm screws using the Phillips #00 screwdriver.
    • Remove the two 6mm screws using the same screwdriver.
    • Remove the fan cover to gain access to the fan.
  4. ACER Aspire 7750G-6645 Fan Replacement: passo 4, immagine 1 di 2 ACER Aspire 7750G-6645 Fan Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Desoldering Pump
    $3.99
    • Lift the fan up and away from the device. Do not remove the fan from the device.
    • Desolder the attached part using a Soldering Iron to heat it up and remove the leftover heated lead by using a Desoldering Pump.
    • If you aren't familiar with soldering, read our How to Solder and Desolder Connections guide for more information.
Conclusione
taylan ergil
Membro da: 03/08/19
85 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 20
Tutti i Tempi: 723
