Salta al contenuto principale
4Sight 9 Digitizer Replacement
Cosa ti serve
  1. 4Sight 9 Digitizer Replacement, Cover: passo 1, immagine 1 di 2 4Sight 9 Digitizer Replacement, Cover: passo 1, immagine 2 di 2
    • Place the tablet on its side so that the two screws are facing upward.
    • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
  2. 4Sight 9 Digitizer Replacement: passo 2, immagine 1 di 1
    • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
    • Once loosened, use your hands to separate the case from the device.
  3. 4Sight 9 Digitizer Replacement: passo 3, immagine 1 di 2 4Sight 9 Digitizer Replacement: passo 3, immagine 2 di 2
    • Hold the positive and negative wires as close as possible to the speaker.
    • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
  4. 4Sight 9 Digitizer Replacement, Motherboard: passo 4, immagine 1 di 1
    • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
  5. 4Sight 9 Digitizer Replacement: passo 5, immagine 1 di 2 4Sight 9 Digitizer Replacement: passo 5, immagine 2 di 2
    • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
    • Put pressure on the connector until the clasp comes undone.
    • Gently pull up on electrical ribbon until it disconnects from circuit board.
  6. 4Sight 9 Digitizer Replacement: passo 6, immagine 1 di 2 4Sight 9 Digitizer Replacement: passo 6, immagine 2 di 2
    • Remove the second electrical ribbon from the motherboard.
    • Use the technique for the previous ribbon.
  7. 4Sight 9 Digitizer Replacement: passo 7, immagine 1 di 1
    • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
  8. 4Sight 9 Digitizer Replacement: passo 8, immagine 1 di 2 4Sight 9 Digitizer Replacement: passo 8, immagine 2 di 2
    • With fingers, grip the green Wi-Fi connector.
    • Gently pull up on connector to remove tape holding the connector in place.
  9. 4Sight 9 Digitizer Replacement: passo 9, immagine 1 di 1
    • Using your fingers, gently lift the motherboard.
  10. 4Sight 9 Digitizer Replacement, Digitizer: passo 10, immagine 1 di 3 4Sight 9 Digitizer Replacement, Digitizer: passo 10, immagine 2 di 3 4Sight 9 Digitizer Replacement, Digitizer: passo 10, immagine 3 di 3
    • Insert plastic prying tool under screen and exert pressure, pulling upward.
    • Repeat this strep around each corner of screen until it pops off.
  11. 4Sight 9 Digitizer Replacement: passo 11, immagine 1 di 1
    • Place heating pad on glass frame in order to loosen adhesive for 3 to 5 minutes.
  12. 4Sight 9 Digitizer Replacement: passo 12, immagine 1 di 1
    • Use fingers to gently pull digitizer off of device.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,192
