Salta al contenuto principale
3DR Iris Plus Quadcopter Propeller Replacement
Cosa ti serve
  1. 3DR Iris Plus Quadcopter Propeller Replacement, Battery: passo 1, immagine 1 di 1
    • Power off the drone by holding down the power button.
    • Remove the battery by disconnecting it from the main battery connector.
    • Press the power button again to ensure all electricity is discharged.
    • This step is imperative as it is dangerous to handle drone components with a running current!
  2. 3DR Iris Plus Quadcopter Propeller Replacement, Propeller: passo 2, immagine 1 di 2 3DR Iris Plus Quadcopter Propeller Replacement, Propeller: passo 2, immagine 2 di 2
    • Take note of the propeller cap color (either black or silver).
    • Hold down the motor assembly and twist the propeller clockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
    • Hold down the motor assembly and twist the propeller counterclockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
    • This is the motor assembly.
  3. 3DR Iris Plus Quadcopter Propeller Replacement: passo 3, immagine 1 di 2 3DR Iris Plus Quadcopter Propeller Replacement: passo 3, immagine 2 di 2
    • Ensure that the propeller cap color (black or silver) matches the propeller screw cap color.
    • There are two different types of propellers so make sure you're using the correct one.
Conclusione
To reassemble your device, follow these directions in reverse order.
Cal Poly, Team S7-G5, Regan Winter 2020 Membro di Cal Poly, Team S7-G5, Regan Winter 2020
CPSU-REGAN-W20S7G5
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 330
