Introduzione
If you are experiencing poor braking performance or a noise when braking, then it make be time to replace the front brake pads and or rotors.
Follow this video tutorial by YouTuber NutzAboutBolts to complete the replacement yourself.
Depending on the Toyota Dealership Parts & Service Department; 3M Silicone Paste, 3M Copper Anti-Seize, Sil-Glyde or the Toyota caliper guide pin and anti-seize/squeal lubricant are recommended respectively.
Torque specs:
- 25 ft. lbs - Caliper sliding pin bolts
- 101 ft. lbs - Caliper mounting bracket bolts
- 25 ft. lbs - Brake line
Safety
If this is your first time working on a vehicle read our safety tips before proceeding.
Cosa ti serve
Istruzioni Video
Altre 6 persone hanno completato questa guida.
3 Commenti
101 ft lbs? Are you out of your mind?
Tom - Replica
@Tom Just going by the Repair Manual.
James Finch - Replica
Lube points?
stevenwdiffy7 - Replica
