Salta al contenuto principale
2008-2010 Audi A3 Sportback Key FOB Battery Replacement
Cosa ti serve
  1. 2008-2010 Audi A3 Sportback Key FOB Battery Replacement, Key FOB Battery: passo 1, immagine 1 di 3 2008-2010 Audi A3 Sportback Key FOB Battery Replacement, Key FOB Battery: passo 1, immagine 2 di 3 2008-2010 Audi A3 Sportback Key FOB Battery Replacement, Key FOB Battery: passo 1, immagine 3 di 3
    • With the tip of a flat head screwdriver, insert it under the edge of the key fob and push against the back cover to pop it off.
    • Take caution as you apply force to open the cover as the flathead screwdriver is a sharp tool.
  2. 2008-2010 Audi A3 Sportback Key FOB Battery Replacement: passo 2, immagine 1 di 2 2008-2010 Audi A3 Sportback Key FOB Battery Replacement: passo 2, immagine 2 di 2
    • Remove the round CR2032 battery from the fob back cover with a plastic spudger or opening tool.
    • The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
  3. 2008-2010 Audi A3 Sportback Key FOB Battery Replacement: passo 3, immagine 1 di 1
    • Insert a new battery and pop the cover back on by hand.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 213
Tutti i Tempi: 8,216
