Introduzione
Are you having trouble with your windows rolling up or down properly in your 2007-2014 Chevy/GMC SUV or Truck? Don’t sweat it! The problem you are experiencing is common in many vehicles and this guide is exactly what you need. If you follow my guide you can become your own mechanic and finish the job in roughly 10-15 minutes. You’ll be back to rolling down your windows in a few minutes!
Cosa ti serve
Using a flat-head screwdriver, wedge underneath the plastic cover to release it from the assembly.
If you continue to have problems with the windows not working properly then it is an issue with either your wiring or motors and should be looked at by a certified technician. Thank you, and I hope my guide helped solve your problem!
Altre 3 persone hanno completato questa guida.
5 Commenti
I have a 2009 Chevy Silverado. i changed the same panel and everything works except drivers window. any thoughts on how to fix it?
I have the same issue with my 2009 GMC Acadia. Does yours click? If so I found a useful how to guide I'm going to try next on this forum
2008 Chevy Silverado 4 Dr extended cab. Won't even start the ignition. And it worked fine before I changed the master switch for all 4 windows, the interior lights are now very dull, the ignition doesn't work, no door locks and none of the window work now...there is only 1 way to put the new switch in right? Now I have a real bucket of worms. Cause I went ahead and took the new master off and put the old one back on. At least with the old one , it started and 2 of the windows worked and the electric locks worked. Now even with the old one back in nothing still works what's so ever.
