Introduzione
This guide will explain how to replace a failing throttle position sensor or TPS in a 2006 Ford Mustang with the 4.0L V6 motor. You may need to complete this repair if you have a rough idle or if the car is hesitating while accelerating. Your car may also display a check engine light. You can have an auto parts store or mechanic read the check engine code to confirm that this is in fact the issue you are having.
Cosa ti serve
