Salta al contenuto principale
2005-2015 Nissan Xterra Fuel Pump Replacement
Cosa ti serve
Istruzioni Video
Conclusione
Altre 2 persone hanno completato questa guida.
eCuration
Membro da: 05/19/17
378.307 Reputazione
236 Guide realizzate
iFixit Membro di iFixit
Staff
140 Membri
18.077 Guide realizzate
3 Commenti
I own a 2010 nissan xterra and I would like to see where the fuel check valve is located. I'm having trouble with the car not starting when it's cold. However, if I let the truck sit with key in the on position like you did to prime the pump, it starts right up. I've found info about a vapor canister check valve but I'm not 100% sure my model has sush a part. Great video, and will be referencing you for future projects.
David N Bobbitt - Replica
its the fuel pump, I am doing mine today, the check valve is inside the stupid pump
joshuacay - Replica
Howdy. Former Air Force Maintenance guy here. Had to do this on the previous generation where it was under the seat and SO much easier. But, I have a safety recommendation for you all on this. Using a tiny tube, siphon as much gas out as you can. Then, however your preference, get a hair dryer, TURN OFF THE HEAT. OPEN ALL GARAGE DOORS TO THE OUTSIDE, or just BE outside. Now pump as much fresh air volume into the tank continuously for several hours, or for a day for good measure. Fuel pump opening is probably best for volume. This will evaporate out all volatiles and even any water that may have collected in the sump. You now have a fully safe tank to work with, and can easily wipe out that nasty orange grunge for a really clean, like new tank. This is how we make BIG plane tanks safe to crawl into. Only took a couple of hours with full airflow for mine to be completely safe to work with.
desertengineer1 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 157
Tutti i Tempi: 13,963
