Salta al contenuto principale
2003-2007 Honda Accord Engine Air Filter Replacement
Cosa ti serve
  1. 2003-2007 Honda Accord Engine Air Filter Replacement, Opening the Hood: passo 1, immagine 1 di 2 2003-2007 Honda Accord Engine Air Filter Replacement, Opening the Hood: passo 1, immagine 2 di 2
    • Locate the hood latch beside the driver's side door, next to the left foot rest.
    • Pull the latch toward you to release the hood.
    I change my oil every 5.000 miles like clockwork I did a compression test a few weeks ago and it's only lost about 2% of it compression and done 160.000 miles so well worth it
    Graham Wells - Replica
    What if u can’t get inside to unlock the hood
    Paula Charron - Replica
    My fob is not working properly I guess I checked the battery and it’s good still won’t open car a Sonata hybrid 2021 what do I do?
  2. 2003-2007 Honda Accord Engine Air Filter Replacement: passo 2, immagine 1 di 2 2003-2007 Honda Accord Engine Air Filter Replacement: passo 2, immagine 2 di 2
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
  3. 2003-2007 Honda Accord Engine Air Filter Replacement: passo 3, immagine 1 di 2 2003-2007 Honda Accord Engine Air Filter Replacement: passo 3, immagine 2 di 2
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • You can now let the hood rest on the stand.
  4. 2003-2007 Honda Accord Engine Air Filter Replacement, Engine Air Filter: passo 4, immagine 1 di 3 2003-2007 Honda Accord Engine Air Filter Replacement, Engine Air Filter: passo 4, immagine 2 di 3 2003-2007 Honda Accord Engine Air Filter Replacement, Engine Air Filter: passo 4, immagine 3 di 3
    • Be sure your engine is turned off.
    • Identify the engine's air duct hose.
    • The emission hose is located on the top.
    • Remove the emission hose by gently wiggling it out of place.
  5. 2003-2007 Honda Accord Engine Air Filter Replacement: passo 5, immagine 1 di 2 2003-2007 Honda Accord Engine Air Filter Replacement: passo 5, immagine 2 di 2
    • Remove the smog hose by squeezing the tubing and pulling it off.
  6. 2003-2007 Honda Accord Engine Air Filter Replacement: passo 6, immagine 1 di 1
    • Using a Phillips screwdriver, loosen air duct clamp screws.
  7. 2003-2007 Honda Accord Engine Air Filter Replacement: passo 7, immagine 1 di 2 2003-2007 Honda Accord Engine Air Filter Replacement: passo 7, immagine 2 di 2
    • Once the screws are loose, completely remove the air duct hose by gently wiggling it off the engine and the air filter housing.
  8. 2003-2007 Honda Accord Engine Air Filter Replacement: passo 8, immagine 1 di 3 2003-2007 Honda Accord Engine Air Filter Replacement: passo 8, immagine 2 di 3 2003-2007 Honda Accord Engine Air Filter Replacement: passo 8, immagine 3 di 3
    • Remove the air filter housing cap.
    • Using a long Phillips screwdriver or a long 5/16 Hex driver, remove the four screws holding down the air filter housing cap.
  9. 2003-2007 Honda Accord Engine Air Filter Replacement: passo 9, immagine 1 di 1
    • Lift the engine air filter housing cap and place it aside.
    • Do not turn the housing cap upside down. Screws left in holes of housing cap might fall out.
  10. 2003-2007 Honda Accord Engine Air Filter Replacement: passo 10, immagine 1 di 1
    • Lift the dirty filter out of the housing.
    • Vacuum any dirt or debris out of the air filter box.
  11. 2003-2007 Honda Accord Engine Air Filter Replacement, Filter replacement: passo 11, immagine 1 di 1
    • Replace the old filter with the new filter.
    • Ensure that it seats properly in the lip of the air cleaner box.
    • Screw down the air filter housing cap. Connect air dust, emission, and smog hoses.
Conclusione
To reassemble your device, follow instructions in steps 1-5 in reverse order.
Altre 22 persone hanno completato questa guida.
Cal Poly, Team 24-27, Regan Fall 2012 Membro di Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Membri
22 Guide realizzate
4 Commenti
Okay, I have an Acura TSX (Euro Accord) with the K24A engine, which is similar, and can assure you that you do not need to remove all these connections and hoses just to open the engine air cleaner . The AIR CLEANER COVER (where the filter lives) can be gently lifted up sufficiently to open up, remove the AIR CLEANER ELEMENT ASSY (filter), vacuum out debris from AIR CLEANER CASE, and install a new filter.
David Spalding - Replica
For a 2006 Accord L4, you definitely need to remove the air intake hose as the front lip of the air cleaner box will not clear the inner fender by about 1/4" on the left side. Never had problems with any other newer or older hondas and toyotas with having to remove the air intake hose to open the air cleaner box. This is why I came here for advice. thanks OP.
Michael Lee - Replica
emission hose where can I find it at ? Mine broke
Moda Zuniga - Replica
You use metric tools on Hondas because they are a foreign car. Use an 8mm socket with an extension to remove the screws from the air filter cover.
Mary Petersonma - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 149
Tutti i Tempi: 33,302
