Salta al contenuto principale
How to eject dvd after wii failure?
My wii, yesterday just died. As i was playing New Super Mario Bros. The DVD is still inside it, since naturally i didn't have the time to eject it. Is there any way to eject the disk, since the console won't power on? A step by step guide, if it's an easy fix, would be most appreciated.
Questa è una buona domanda?
Punteggio 3
1 Commento
maybe it reached a scratched spot on the disc.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Here's an excellent guide for handling this problem: http://www.somelifeblog.com/2008/06/nint...
Punteggio 7
2 Commenti:
This may be more extensive than you're willing to go, but...
If you follow this guide, you can remove the optical drive. From there, you can manipulate the white plastic sliders on the metallic side of the drive to slide the disc out. Alternatively, one the drive is removed, you have your choice of removing the screws on the metallic side of the drive, lifting up the casing, and pulling out the disc.
I've also heard of people inserting another disc with double-sided tape on it into the slot and fishing the drive out, but I can't comment on whether this works or not.
Good luck!
Punteggio 5
2 Commenti:
I need help I have a old broken wii and I want to get the disc out for my new one but I can't seem to get it out plus I don't really wanna open it.
Pls help
Punteggio 0
Aggiungi la tua risposta
Thanos Georgoulis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 61
Ultimi 30 Giorni: 252
Tutti i Tempi: 54,458
