Salta al contenuto principale
La saldatura è un metodo di connessione di due pezzi di metallo sciogliendo un metallo d'apporto fra di essi. Ci sono molti tipi di saldature, ma questo articolo è stato scritto per insegnarti le basi della saldatura elettrica.
56 Domande Visualizza tutte
Anyone recommend magnified glasses for soldering?
I've been looking for a pair of magnified glasses for solder work, such as on iPods.
I ordered a pair with loupes, a few months off Amazon, they didn't have an adjustable focal length, and 2" of space between my nose and a hot iron ain't gonna fly. ;)
I was looking at something like this on Amazon : Eschenbach MXDT-16245-01
It would be nice to find a pair, at a reasonable price, with 10x+ magnification and a minimum focal distance of say 2'.
Any suggestions or recommendations?
Questa è una buona domanda?
Punteggio 3
2 Commenti
Wow! I feel sorry for 2012. The best was a 2X $199 pair of glasses? Here in 2018 we have $12.95 "Headband Mount Magnifier LED Illuminated Head Magnifying Glass" with interchangeable 5 replaceable Lenses:1.0X/1.5X/2.0X/2.5X/3.5X. I'm loving mine, even for SMD/SMT soldering! Search Amazon for quoted part.
da
Aggiungi un commento
9 Risposte
Soluzione Prescelta
I have a pair of dentist glasses
( same kind of glasses your dentist would have, best description i can give but same kind of thing your looking at on amazon, just with a headband kind of thing) ........
just get the correct power you need, i have no idea what the mag. on mine is...... they allow me plenty of room/distance from what i am working on and just flip up the glasses like a welding mask makes it easier then glasses.
Check out ebay or maybe amazon,i have had mine for many years so not sure where you should buy them..... should be quite a bit less expensive then the amazon.com glasses you referenced.
Punteggio 6
4 Commenti:
could you provide a link to a image of what you are using?
da
That did take me awhile to find..... http://www.ebay.com/itm/Opti-Head-Visor-...
This is just an example above of what i could find i didn't read the specs, after using several search terms .... " jeweler glasses head "..... is what did the trick, jeweler goggles could prob. also be used.... or visor glasses etc.
da
I've been using these for years. They do have different strength lens available. I also have one set with lights built into the sides. For different types do a search using "images" for "jewelers headband magnifier".
da
Hi I am new to this repair game and I use my magnifying light. It has good magnification and a wide lens about 3-5inches diameter. They have a light on them that shines onto your work. They attach by clamp to the table . They are used for fine sewing and knotting wigs. They are fantastic, to adjust the distance from the work you just move the lens you can get in close or work further away.
Punteggio 2
7 Commenti:
da
I bought it in an haberdashery shop selling sewing stuff. I can describe it for you thought. They came in black or white. They have a metal arm which has springs on so you can adjust the distance to the object. There is a plastic clamp with a hole on two sides to slot the arm into, the clamp can screw onto a table top and also on some chairs. You can also buy a separate heavy plate which has a hole in the centre to stand the arm onto the table (like a Lamp). The head of the arm is round and has a bulb underneath. It then has a little sliding slot which covers the magnifying glass. It then of course has a lead and plug. Any haberdashery shop which sells embroidery or tapestry items will stock these as they are needed for close work. I hope this helps. Try John Lewis. I hope that helps. Cheryl
da
Does it look at lot like this? Illuminated Magnifier Table Lamp
da
I hate to say it, but the one iFixit sells is junk. The neck does not extend far enough to be useful, and it is not properly weighted, so if you try to extend the neck out at all, it falls over on itself and right into the middle of what you are working on. It's definitely worth investing in a higher quality tool than this.
da
I haven't tried the one from iFixit, I use one like this: http://www.modelsandhobbies4u.com.au/too...
da
Mostra altri 2 commenti
I use a 20x microscope when soldering. It is attached to a boom stand and gives 6 inches of work room. I have all types of glasses and magnifiers, but if you really want to see what you are doing you need more than a pair of loupes.
Punteggio 1
If your doing this professionally you could go to your local optometrist and ask him for a set of 'doctor telescopes' (Its what dentists & surgeons use) They look like eye glasses with a big camera lens sticking out in the middle of the normal glasses lens.
They are expensive! But boy! do they make it a breeze working on fine detail work (I found a pair at a flea market). They are like a hand magnifier (watchmakers loupe) but at an arms length away and can be adjusted.
Punteggio 0
2 Commenti:
Dan, could you put these on for us, take a picture and use it for your profile ;-) I'm sure that would give us all a good grin!
da
These are called dental/surgical loupes. At the top end, they can be anywhere from $2k to 4k with only 4x magnification (from Zeiss).
da
A dioptic fixture is what is used by pros . It works great and has a lite w/it
Punteggio 0
This is an expensive solution, but if you are doing a lot of tiny sight-intensive work, I highly recommend CraftOptics. The folks there are super helpful, and will devise a pair of magnifying glasses that include your prescription. The glasses also have an optional LED light that I find indispensable, which attaches to the glasses and runs off of a rechargeable battery pack. There are other solutions, but I find these magnifying glasses to be the best to see with, easiest to wear, and with them I can see better than I ever imagined. The customer service offered by CraftOptics is the very best. I do not work for them, and am not related to anyone who works there. The glasses and the company are just great!
Another solution is a magnifying lamp made by Brightech - specifically, the Pro Lightview XL, of which there are 3-4 different models. This lamp pivots and can be positioned over your work without tightening screws, and it also can be adjusted to sit on a desk or stand on the floor. One looks through the lamp head which has a large rectangular 5-diopter glass magnifying lens brightly lit by LED lights that can be dimmed. I love this lamp!
I use both of these to see while I make beaded jewelry, repair electronics, solder jewelry and electronic connections, etc. They are both invaluable to me and I use both every single day, Good Luck!
Punteggio 0
When I first began fixing electronics as a hobby, all I needed was a reasonably priced, modest but dependable magnifying lens. The good news is that despite only costing a few dollars, this Elenco magnifying lens was indispensable to my soldering. I can now use the extra cash to buy different tools for my soldering work.
Punteggio 0
I've used this for years, it works great:
https://www.lazada.com.my/products/ready...
It has adjustable magnification of around 2 to 20 times and an adjustable LED light. You can probably find it on other sites too, such as aliexpress.com
Punteggio 0
Hey,
okay, old thread, but:
i'm working successfully with this model, since round about 7 years:
https://www.ebay.de/itm/176271149776
Best Regards
Georg
Punteggio 0
Aggiungi la tua risposta
Country Computer Service sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 157
Tutti i Tempi: 31,836
