Salta al contenuto principale
The Flipper Zero is a versatile multi-tool device designed for hacking, debugging, and experimenting with various electronic gadgets and systems, such as sensors, receivers, and other electronic components.
8 Domande Visualizza tutte
Flipper Zero. Stripped the screws a bit. What do I do?
I used a small metal screwdriver when trying to replace the housing shell and I think that it was stripped a little, but not as much. I don’t want to continue to try to unscrew it with the risk of completely stripping it. Any ideas?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
If you are un-screwing, usually the problem is using too big or too small of a screwdriver. Get the size that is big as possible that fits and press in as hard as possible when unscrewing. I don't yet have a flipper, so I can't recommend a screwdriver. ( but plan to buy one soon, such an amazing device)
Punteggio 0
Aggiungi la tua risposta
KingCool sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 25
Tutti i Tempi: 151
