Salta al contenuto principale
Il nuovo formato di Apple per la linea 14 ha uno schermo OLED da 6,7 pollici, come il Pro Max, ma le stesse caratteristiche dell'iPhone 14 con doppia fotocamera e chip A15 Bionic con una GPU a 5 core.
12 Domande Visualizza tutte
Extra part after disassembly, please help!
Hi guys,
I've taken apart my Iphone 14 Plus to put everything in a new housing. unfortunately in the process I've taken something out which I now don't know where belongs. Can anybody please help?
Thanks a lot!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Thanks for the input @flannelist. Some very close inspection of teardowns helped me to find the location. It's something between the speaker and the charging port part. I've attached a picture below. Phone all working now! Thanks!
Punteggio 1
Risposta Più Utile
I have not worked on one of these yet. But Apple loves little bits like these. It looks like an antenna of some kind. Based on the way its shape I would wager it goes into the side of the housing somewhere, like a button flex. My first through would be the NFC antenna which is usually in the sidewall of the housing near the rear camera. But I haven’t been able to pin down the location for sure.
Here’s a pretty in depth teardown for the 14 Plus on a top down view. You might be able to find the placement based on this.
https://youtu.be/QlkC6_AiinU?si=9s53xDZB...
Punteggio 2
Aggiungi la tua risposta
Michael Buijs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 70
