il microfono che registra non funziona
Mi è caduto il cellulare in acqua, funziona tutto tratte il microfono che registra l'audio che emetto, cosa devo fare?
Questa è una buona domanda?
@alex4683787 start off by running the hardware diagnostics. Run a diagnostic test: Go to Device Help App > Device Diagnosis > Hardware Test Let us know what that tells you.
Since your phone was water immersed and you did not tell us what you have done about that, I suggest that you address the water damage issue as well.
The very first step I would take is to disassemble your phone. Use something like this video as your guide. Carefully inspect all the components and connectors. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. so you do not have to wait for the parts to dry. The importance here is the cleaning. It would of course be best to get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Your issue here seems to be the primary microphone. It is located on the sub board (charging board). I would go ahead and replace the complete board based on the water damage. You re looking for a board like this After that, reassemble your phone and re-evaluate.
Translation
@alex4683787 iniziare eseguendo la diagnostica hardware. Esegui un test diagnostico: Vai all'App Guida del dispositivo > Diagnosi del dispositivo > Test hardware Facci sapere cosa ti dice.
Dal momento che il telefono è stato immerso nell'acqua e non ci hai detto cosa hai fatto al riguardo, ti suggerisco di affrontare anche il problema dei danni causati dall'acqua.
Il primo passo che farei è smontare il telefono. Utilizza qualcosa come questo video come guida. Ispezionare attentamente tutti i componenti e i connettori. Cercare la corrosione maggiore, valutare i pin nei connettori, ecc. Esaminare tutti i connettori e le estremità dei cavi. È necessario rimuovere tutte le schermature EMI. Se non si rimuovono le schermature, non si pulisce la scheda. Una volta eliminata la contaminazione grossolana, utilizzare alcool isopropilico al 90% e pulire ulteriormente i componenti. Per una pulizia corretta, utilizzate [guida|5825|questa guida]. È stata scritta per un Apple iPhone 3G ma è comunque pertinente anche per il vostro telefono. Non potrò mai sottolineare abbastanza l'importanza di una buona pulizia, quindi fatela più volte sostituendo l'alcol dopo ogni pulizia. L'alcol isopropilico in alta concentrazione evapora rapidamente e disperde l'acqua, quindi non è necessario attendere che le parti si asciughino. L'importanza è la pulizia. Naturalmente sarebbe meglio affidare la pulizia a un professionista Non dimenticate di sostituire la batteria. È un obbligo e non un'opzione. Si guasterà se non ci si occupa subito della batteria. Finché non avrete pulito la scheda e sostituito la batteria, tutto sarà solo un'ipotesi. Tenete presente che i danni causati dall'acqua sono i più difficili da risolvere e da riparare. Non importa se è stato esposto per 2 secondi o per 2 ore, ciò che conta è dove l'acqua (particolato) ha causato il danno.
Il problema sembra essere il microfono primario. Si trova sulla scheda secondaria (scheda di ricarica). In base ai danni causati dall'acqua, procederei alla sostituzione dell'intera scheda. Cercate una scheda come questa Dopo di che, riassemblate il telefono e valutate nuovamente.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 16
