Salta al contenuto principale
Il top di gamma di Apple per il 2022. Lanciato sul mercato il 16 settembre, l'iPhone 14 Pro Max sfoggia uno schermo ProMotion OLED da 6,7", il nuovo chip A16 Bionic, un sistema di fotocamera tripla e connettività 5G. È il successore dell'iPhone 13 Pro Max.
24 Domande Visualizza tutte
Are iPhones water tested with just fresh water?
I was just wondering if chlorine would do any damage to the iPhone even tho is water resistant. Mine got splashed with a significant amount of water from the pool and I got the notification that the was water in the charging port, took 4 hours before the phone could charge again. The phone seems fine, just wanted to know if it’s something to worry about
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
It depends how long it was soak, or did you dry it immediately but there are water probably in some parts inside and dried water cause corrode any expose components inside-cause corrode so many tiny pins inside, most components are integrated circuit these are very still vulnerable to short circuit and cause an issues….you will know however if your phone behave not normal means something wrong…Phone are not really water resistant as the (30 mins )….manufacturer claims, though can can cope with a bit splash, moist, never submerge to water (fresh, salt is worse as it penetrate the board or any components inside, the problem of phone being soak to water is…. when is on as all components are working 100% then suddenly short circuit…. this damage most of the components inside (ICs) can pcb or board main board whatever you gonna call it can be submerge to water or can it be washed absolutely yes but with no supply voltage it can be be clean with water or 99.9 % alcohol…I am a repair tech… mainly high end amps….
Punteggio 1
Aggiungi la tua risposta
John sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 54
