Salta al contenuto principale
Repair guides and disassembly information for the fourth-generation Mac Pro, released in December of 2019.
13 Domande Visualizza tutte
Mac OS Recovery Fail
Hello,
Computer: Mac Pro 2019 Intel Processor
Problem: I am running into a problem where I am unable to enter macOS Recovery over the internet.
Originally, I wanted to erase my hard-drive to reset my mac. However, I forgot to use Bootcamp Partition to delete the Windows version. When I was in the macOS Recovery downloading the latest version of macOS Ventura, my internet shut down and the download could not continue. When I restart my mac trying to start up using macOS Recovery over the internet. I was prompt with this message.
Recovery
Your PC/Device needs to be repaired
Error Code: 0xc0000225
I was hoping to bring it into apple and them diagnose but I wanted to see if I can find solution at home first.
Thanks,
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Try in recovery mode and quit the recovery tools and check if gives you an option to restart.
It should ask you to choose a disk to boot on, check if MacOS or Windows comes up, select MacOS and do a partition.
Hope this works!
Punteggio 0
I find using the internet recovery has its good days and bad 😞 Apple tends to forget about updating it. And if you have a no longer supported system and OS version it uses forget it!
I would creat a bootable OS installer with the MacOS you are currently using, of course you need a working Mac to do that😩!
Get a 32GB thumb drive and try to hunt down a friend with a Mac to help you if you don’t have a second Mac.
Here’s the needed OS file How to download and install macOS and here’s how to make the bootable image Create a bootable installer for macOS
Punteggio 0
Aggiungi la tua risposta
Young sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 32
Tutti i Tempi: 275
