Salta al contenuto principale
The Nokia Lumia 2520 was officially unveiled on October 22, 2013, and released in North America on November 21, 2013. Very first Windows RT tablet computer developed by Nokia.
1 Domande Visualizza tutte
Instead of using the heat mat, can I use a heat gun...
Instead of using the heat mat, can I use a heat gun to take off the screen to get to the battery?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Yes you can. Apply heat around the edges then insert your opening tool freeing a bit of adhesive at a time. Then repeat until the screens off. Using some isopropyl alcohol as well will make the job a lot easier.
Punteggio 2
5 Commenti:
Do I need to use plastic picks? or can I use a spudger?
da
@nytryder26 I’d use a thin opening tool to make an opening then a thin piece of plastic. Plastic picks or a spudger might be too thick cracking the screen.
da
@strongbow Like this kit? iOpener
da
@strongbow Ok Ill check it out!
da
Aggiungi la tua risposta
NR26 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 83
