Salta al contenuto principale
Repair and troubleshooting information for the Kushlan 350DD, an electric wheelbarrow-style cement mixer.
1 Domande Visualizza tutte
Barrel not spinning or frozen.
After storing for a few months, I flip the switch, and it is making a humming noise. However, the barrel does not spin, I cannot spin it manually before I take it apart, I was wondering if anyone had experienced the barrel, frozen or not spinning. I did check in the breaker button is not tripped.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
There should be a large capacitor on the motor. That could of gone over time. Most mixers are ran on a worm drive gearbox so you can't rotate the drum by hand. Is there any way to safely rotate the drive mechanism? It could be jammed with sitting.
Punteggio 2
2 Commenti:
After testing, it appears to be a dead capacitor. Thank You!
da
@Joseph Galaska No problem, hope you get it working.
da
Aggiungi la tua risposta
Joseph Galaska sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 81
Tutti i Tempi: 487
