Salta al contenuto principale
Sewing is the practice of fastening two pieces of fabric together using a needle and thread. Here we will cover the fundamentals of sewing by hand and sewing machine operations.
6 Domande Visualizza tutte
Singer sewing machine 132K6 top thread problems
I got an old Singer sewing machine 132K6 recently. It has not been used for over a decade at least and apparently full of dust and rust. I have cleaned, removed rust and lubricated moving parts. When I plugged in outlet, it works! But there are a couple of problems.
The needle can not pick up bottom thread when sewing a fabric. The rotary hook’s timing is adjusted and can grab the bottom thread. However when I tried to sew fabric, the needle won’t pick up bottom thread. Please see the attached pictures.
Another problem sometimes the upper thread was broken like it was cut by a knife.
Need help
Any help and advice are appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Try slackening off the top thread tension.
Regards
Punteggio 0
Aggiungi la tua risposta
Jack Smith sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 104
