Salta al contenuto principale
The Twentieth Anniversary Macintosh was a limited-edition personal computer produced by Apple Computer, Inc., in 1997 in celebration of the 20th anniversary of the company
6 Domande Visualizza tutte
Replace hard drive in TAM
My TAM is no longer recognizing the hard drive. It boots up with the system/floppy disk icon with a “?” Using the software CD neither Disk First Aid or Disk Setup show the hard drive as part of the setup. I’m assuming I have a bad hard drive or something wrong with the boot sector.
Do you have the guide on how to replace a hard drive in the TAM?
Thanks!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
Accessing the hard drive is fairly easy on the TAM. There are two tension clips near the bottom of the back which will let you lift off the cover (this is shown in the logic board removal guide). At this point you are basically looking at the drive. It is mounted horizontally, on top of the processor heatsink. It has a small assembly with a fan that is held on with four Phillips head screws. Remember to remove the fan connector as well.
The drive is just a standard issue IDE laptop drive. You can find one in most late 90s and early 2000s laptops. Booting from a system disc will let you initialize and format the drive. Even if it's 40GB your Mac will likely only see 4.5GB (this is normal and there is more nuance on this topic). The screw holes might not line up on the bracket so you may need to be a little creative. But as long as the pins align you should be in business for very low $$.
Punteggio 1
Aggiungi la tua risposta
Micheal DiPaolo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 262
