Salta al contenuto principale
Lo smartwatch Apple di quarta generazione, con connettività cellulare opzionale, lanciato il 21 settembre 2018.
125 Domande Visualizza tutte
Screen white after replacement
Hi everybody
I had to change the screen of my Apple Watch 4 44mm. For that, I bought a locked watch with a perfectly working screen. After switching the broken screen of my watch with the working one, the replaced screen is only white. I checked the cables and changed the Touch Force sensor as well. The screen is still white. Does anyone have any idea why?
Thanks and greetings
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Maybe screen curtain is active, have you tried to disable it?
"Use Screen Curtain on your Apple Watch
Use your iPhone to turn on Screen Curtain for your Apple Watch:
  1. On your iPhone, open the Apple Watch app and go to My Watch.
  2. Tap Accessibility > VoiceOver > Screen Curtain. This setting keeps Screen Curtain active whenever VoiceOver is on.
  3. To turn Screen Curtain off, repeat these steps."
Punteggio 0
Did you find a solution? having the same issue.
Punteggio 0
Aggiungi la tua risposta
DeFidel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 513
