Salta al contenuto principale
L'aggiornamento di marzo 2015 del MacBook Air da 11" di Apple offre processori Intel Core i5 e i7 di quinta generazione, con un leggero aumento delle prestazioni e della durata della batteria.
142 Domande Visualizza tutte
What screwdriver do I need to open the battery panel? MacBook Air 2015
I spilled a little vinegar on my laptop days ago. I’ve just got the right screwdriver to open the back of it but I’ve discovered that I need two different screwdrivers to open the battery panel. Where can I get this in stores! Please help! Thank you. MacBook Air 2015
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Here’s the iFixit guide you need to follow: Sostituzione batteria MacBook Air 11" inizio 2015
You need the following screw drivers:
Immagine T5 Torx Screwdriver
Prodotto
T5 Torx Screwdriver
$5.49
Immagine P5 Pentalobe Screwdriver Retina MacBook Pro and Air
Prodotto
$5.99
Punteggio 2
3 Commenti:
My laptop isn’t turning on. Do you think the batteries are just the problem? Where do I get new ones?
da
Before you jump into getting a battery. How about doing some basic tests.
When you plug in your charger what color is the MagSafe plug Amber or Green?
If the charger is not lighting inspect the contacts for damage and clean the contacts if needed.
Is the charger the correct one for your system?
da
The charger lights up when I plug it in. It turns from green to amber. I don’t want to start my laptop again because it shortens it. When I start it it turns on and then shuts down real quick. I can’t believe it’s not working. When I spilled a minuscule of liquid on it and wiped it up right away. I don’t see any corrosion inside nor any liquid. I don’t know what’s the problem. If you could please help me thank you
da
Aggiungi la tua risposta
aimee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 164
Tutti i Tempi: 7,364
