Why is my Battery Draining
If I don’t start my 04 Mustang Mach I in two days, the battery is dead. Pulled individual fuses, no problem. Pulled the #6 High Currency Fuse (located by the battery) and the draw stops. #6 controls the Powertrain Control Module (replaced with a reman with plug and play), I/P Fuse panel and Instrument Cluster. I’ve called three Ford Dealerships and Ford Motor Company who could not provide me with any information as to what the I/P Fuse panel is or where it is located in order to determine if there is a short. Can you help?
Questa è una buona domanda?
8 Commenti
I have the same problem with my 2003 SVT Cobra, if I let my car sit for 3-4 days my battery will die. Changed the battery and had the alternator rebuilt but the battery will still drain . I suspect the voltage regulator might be faulty.
da Edward Broomall
if you have a aftermarket anti theft device installed under the steering column they wont let the main relay go to sleep mode, so it keeps a constant draw above 1 amp. sleep mode draws about 0.025 amps. when you turn engine off, sleep mode occurs about 15 mins later
da Sean Case
I just bought a 2003 mustang… battery was dead bought brand new one and drove home…whome...went out to start car this morning battery was again dead…also car feeks like it's losing power pulling a hill
da Johnny Hobbs
Where is the hood light located?? My father is having this same issue with his 2000 Ford Mustang.. the hood light is the last possible thing he has to check.. he just needs to know the location.. (there isn't a light anywhere.. that's visible..) Thank you.. any help is appreciated
da Carmen Soliz
I have a 1999 mustang the v6 3.8 and it’s doing the exact same thing however my speed odometer , my fuel gage and my mileage don’t work either and I can’t figure it out. And then the other day I was talking to a guy who worked on fords all his life and he said it’s a common issue with the mustangs around that year and he told me that it was the ecm under the stereo he said that he had the exact same problem in his moms fox body mustang, he said he got a new ecm and it fixed the problem completely so I’m gonna try it and see what happens.
da Matthewsmartin83
Mostra altri 3 commenti
