Salta al contenuto principale
Lanciato il 20 settembre, il più grande e costoso smartphone Apple del 2019 si caratterizza per il display OLED da 6,5", un sistema di fotocamera tripla e un'autonomia della batteria molto migliorata. È il successore dell'iPhone XS Max.
165 Domande Visualizza tutte
Where is the microphone on iPhone 11 Pro Max?
Where is the microphone on iPhone 11 Pro Max? Is it on the side of the lightning charger hole (bottom) or at the top. (If at top, where someone thinks it is, how does that make sense when you’re on a call, using only the iPhone to speak into, with ear to phone? You mouth is close to the bottom (lightning port charge hole). Thanks!
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The microphone for calls would be located on the bottom left loudspeaker grill. The 2nd microphone for siri is on the proximity sensor flex cable, located right under your ear speaker on top. Finally the 3rd microphone is behind the device near your camera, it's a small tiny hole, used for picking up sounds when you're recording a video. I hope this helped.
Punteggio 5
4 Commenti:
When you have your phone against your ear the proximity detector will engage the camera & speaker mics to cancel the background noise both for your active mic as you are talking as well as the speaker if you are using hands free.
da
GREAT ANSWER!!!!!!!!!!! (had to have 20 characters to post)
da
I just ran a check that seems to contradict this answer: I put the iphone 11pro in video recording mode, and tapped first the lower left mic, second the top front mic and third the back mic located with the camera lense cluster. Then listening with earphones I played back the video. The only mic where I could hear the tapping was the first one, bottom left. According to this answer I should have heard the back mic, with the lenses...but no.
da
RE: Bill's comment -- at least as far as shooting video is concerned, if you use an app like Filmic Pro, you can select which mic you want working (under settings, audio.) You can also select your lens.
da
Aggiungi la tua risposta
rachel.spencer999 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 67
Ultimi 30 Giorni: 324
Tutti i Tempi: 68,018
