Salta al contenuto principale
Model A1224 / EMC 2316 / 2.26 GHz Core 2 Duo processor / Education only model. Released on March 4, 2010.
16 Domande Visualizza tutte
Upgrade OS to High Sierra?
I have upgraded to El Capitan, but would like to know if the model could be upgraded (clean install) to High Sierra or perhaps Sierra? According to the spec’s listed for the OS X High Sierra, this model should be able to be upgraded to High Sierra.
If it is not able to be upgraded, could you elaborate on why it would not be able too? Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The Core 2 Duo based systems are not able to run 64bit apps natively.
Punteggio 0
Risposta Più Utile
High Sierra and Sierra both require a Late 2009 or newer model iMac. Yours is a Mid 2009 model so it cannot run either.
Punteggio 1
4 Commenti:
Slight correction The highest is El Capitan OS-X 10.11.x
iMac "Core 2 Duo" 2.26 20-Inch (Mid-2009)
da
Oops. Edited.
da
Is this a limitation of the processor? If a new SSD hard drive were to be installed, would that make a difference? Thanks!
da
The CPU is the issue not storage. But! Putting in a SSD will improve performance! Sostituzione Disco Fisso nell'iMac Intel EMC 2266 da 20"
I would also max the RAM to 8 GB. Installazione della memoria RAM nell'iMac Intel EMC 2266 da 20"
da
Aggiungi la tua risposta
Rob sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 693
