Salta al contenuto principale
Apple released the second generation multi-touch, wireless Mouse on October 14, 2015. Model A1657. Please take a look at the repair guides and troubleshooting tips here.
22 Domande Visualizza tutte
Fixing Magic Mouse 2 which stopped working on some normal surfaces
Hi,
Up until yesterday everything was fine, my Apple Magic Mouse 2 was working correctly on all surfaces.
Suddenly, the Magic mouse has stopped working on most regular surfaces and almost all fabrics (moving the mouse may move the cursor a little bit on these surfaces).
It does work on a transparent nylon, a very soft fabric (EDIT: 100% polyester) and on a leather couch and a specific part of my bare knee. (everything else like touch gestures works).
What is the reason for this? the optical sensor?
I already tried cleaning the optical sensor with a cloth, connecting it to another mac and removing the mouse preferences files with no luck.
Questa è una buona domanda?
Punteggio 12
22 Commenti
BTW, the battery is also showing a constant 100% charge.
It started about one day before this problem so maybe both problems are related.
da
I have the same problem with my Magic Mouse 2. Tried cleaning the sensors with the Qtip, tried with other macs, but no luck.
September 2018
da
Same prob here. Cleaning didn't help at all.
I tried the dropping on hard surface and now the sensor detects rough surfaces better, but it still does not work on all surfaces.
da
Had same problem and was looking for a replacement battery. Saw this thread and slammed the mouse on my desk a few times. It's crazy, but it now works again.
da
Aw man, 4 months I've been using my old plug-in mouse, as well as my magic. Slammed it a couple times, now it works!? :D Thanks folks! :)
da
Mostra altri 17 commenti
Aggiungi un commento
15 Risposte
Risposta Più Utile
All this happened to me, so I searched around, none of the sensor stuff worked etc. I saw a thread where two people were in the same boat and dropped it on a hard surface, and it fixed so I decided what the !&&*. Lol I cannot believe this worked but my mouse is actually fixed now, gave it a nice 4 foot drop onto concrete. Back to normal somehow.
Punteggio 22
32 Commenti:
Wow, I was ready to buy a new mouse, $79 plus tax, your trick worked, mouse is working again! Thanks for your post.
da
Droped it from 3 feet height and It worked. Who would have thought?
Thanks.
da
could not believe, but did work for me too, drop it..!!
da
wow that frickin worked!!!!!
da
Well.... I guess I have to try that now... My mouse only works on dark/black surfaces.
If that works I'll try it on my son...
da
Mostra altri 27 commenti
If you look at the bottom of the mouse you'll see a small window in the shell and inside you'll see two lenses. The smaller one is an IR light source and the larger is the photo detector array. Basically, a grid of light is projected onto the surface and as the light is disturbed the sensor is able to tell which way you are moving the mouse (some very cool stuff is going on here!)
Anyways... you likely have some dirt on the lenses or you likely have a weak battery. Carefully take a dry cotton swab (Q-Tip) and give it a quick wipe (spinning the swab) see if that solves it. You may need to check your cable and connection that you are in fact charging the mouse.
Punteggio 6
1 Commento:
Thanks so much Dan! :)
Just before the problem occurred, I had 1% charge so I charged the mouse, not enough time to get to 100% but it showed a constant 100% ever since.
Maybe both problems have the same root problem of battery, I will update you as soon as I'll have something new, thanks again! :)
EDIT: I think it isn't charging because it thinks it already has a 100% battery charge.
da
Hello everyone,
At last, it has worked for me ! The problem on mine came from the optic sensor. There was dust on it.
In 15 min, the problem was solved.
Unfortunately, it has needed to open the mouse, because the dust was directly on the sensor. But don’t panic, it is far more easy than described by ifixit.
Very easily actually.
  • 1st of all, don’t try to unglue the alloy case from the plastic case nor the ultragliss black feet. It is complicated, long and totally useless.
  • Use a plastic tool as it’s shown on step 6. Put it on both side of the mouse, between the lower case in alloy and the the white upper case of the mouse and it will be removed. There are only 4 clips, 2 by side. (Be kind with the clips, they doesn’t need a lot of torque to be removed)
  • After, remove the 2 screw of the rear of the mouse, those with the metal bracket, and remove the connector of the white upper case.
To remove the motherbord :
  • Remove the 4 screw of the front (3 + 1 with a metal spring),
  • Remove the mother board and unplug the power connector.
To clean the sensor :
  • on the motherbord, remove the 2 plastics parts that protect the sensor : one is transparent with 2 lens, the other is in grey with a little hole.
  • Clean both
  • Now you can access directly to the sensor. To clean it, prefer air.
note : don’t touch it with finger or with cotton, it would be worst.
Now you can reassemble the mouse and try it. I hope it will work also for you.
Punteggio 3
3 Commenti:
Where is "... plastic tool as it’s shown on step 6"? Where's "step 6"?
da
You can find it in the teardown
Sorry my link is in french :
https://fr.ifixit.com/Vue+Éclatée/Magic+...
da
This definitely solves the issue, I took me two hours to get to the sensor (separate the lens and grey middle part was really a challenge) but it was worth thanx for the advise Frech_pit it was really useful.
da
Slamming the mouse down on a hard surface worked for me. The problem originated after leaving the mouse hooked up to USB for charging overnight while computer was shut down. After booting up in the morning mouse no longer “connected” and would not connect until physicality applied i.e. slamming it down on a hard surface; however, this did nothing to make it work on my mouse pad… only hours later after having read about someone, Rey J, slamming it down again, then it worked. Mind you I had tried all other ways through bluetooth connecting beforehand. It looks like Apple products need to be given a $@$* kicking now that Tim Cook is CEO!
In order to avoid this 'slamming down' situation, and since I have two of them, as soon as I notice that my admin mouse's charge is near depleted, I will recharge it while using the other mouse. I now avoid recharging when the computer is shut down.
Punteggio 2
4 Commenti:
Unbelievable, but it worked for me aswell. But does somebody know what is the ratio behind this strange solution
da
da
I was about to open it when I saw your comment. 3 hit on my desk.. back to life.. so weird but it worked
da
good morning from MA! Same story. did the 4 foot drop on to my golf putting hallway pad. Fixed? WtF? TY JMA
da
My mouse stopped tracking on a mouse pad, and eventually on a black wood desktop. Being wary of damaging my year old mouse, I read further about using compressed air on the lenses. I had already tried wiping them, which did not work. As a photographer, I always try my hand blower
before air on possibly sensitive equipment. It worked.
Punteggio 1
I removed the administrator’s mouse from the settings and added back and it solved the problem!
Punteggio 1
1 Commento:
Worked for me too. I did not have to re-pair it after the removal, just had to turn the mouse back on and it instantly appeared in my bluetooth system prefs. I think I had to click on "add".
da
I swear of god, my mouse had the exact problem and after i smacked it on the back of my magic keyboard it works on all surfaces again. the most bizarre fix but it works.
Punteggio 1
Would you believe it?
I had the same problem and it fixed when I dropped it from 3 feet height!
I can’t believe that but it works!!!!
Punteggio 1
yo uso una carpeta plastificada y el mouse funciona perfectamente
Punteggio 0
The same trick worked for me. And it still works. Thank you very much
Punteggio 0
Cool, I'll see if I can find Gen 1 Magic Mouse teardown for my sensor issues.
Punteggio 0
1 Commento:
did you find a gen 1 magic mouse teardown?
My sensor issue is unresolved after slamming, dropping, blowing air and cotton swabbing. I will open it and attempt to clean the sensor next
da
I used a can of compressed air and put the nozzle at the sides of the “sensor-hole” and blew air into my magic mouse 2 a few times and now it works again!!
A couple of months ago, it stopped working on my fabric mousepad and it was only usable on my wooden desk. After a while, it was not responding to most surfaces and I was slamming it on my desk often to get it to work again. The compressed air fix was the last thing I could think of. I will keep a couple of those cans in stock from now on!
Punteggio 0
Hello mbenji
You asked for help
Make sure your devices are charged
To check the battery level of these devices, click the Bluetooth icon in your Mac's menu bar, then select your device by name. If the battery level of any device is low, recharge the device. If the device isn't showing, make sure the device is turned on using the steps outlined above.
Punteggio 0
So strange, I just dropped my magic mouse and now it works again! Thanks for posting this
Punteggio 0
Some additional thoughts and experiences:
I have two Magic Mouse 2s on my desktop at all times, and another one in my computer bag. I hate my life when I have to use any other pointing device. So, when the MM2s mess up it’s super aggravating, and it happens periodically and for different reasons.
When the pointer gets jittery, or just won’t hardly move, I’ve found there are three or four potential fixes:
  1. The dropping the mouse thing does sometimes correct the problem, but probably only because the impact dislodges lint, fuzz, or dirt that was messing with the optical sensors.
# Getting the lens clean is probably the most important fix. I use an actual air compressor and just blow the heck out of the sensor hole. A little puff of canned air may not be enough. I’ve been surprised just how much fuzz accumulates in the sensor hole. Blow it out periodically.
  1. The little plastic rails on the bottom of the mouse can build up a layer of waxy stuff. That waxy stuff seems to misalign the IR sensors from the mousepad and causes weird pointer movements. Scrape the waxy stuff off, and clean the rails thoroughly with a microfiber cloth and maybe some rubbing alcohol.
  2. The mouse-pad surface (or whatever surface you’re running) can affect the performance of the mouse. MM2 seems to like fairly glossy surfaces. Fabric surfaces tend to contribute to the fuzz effect (the fabric may be turning into fuzz, or the fabric may just attract more fuzz), and glossier surfaces like plastic or leather tend to contribute to the waxy buildup effect (which is mostly just your skin oil and dust).
I haven’t had any software-related MM2 issues, only hardware-related, so if the above items don’t fix your mouse, it’s possible its a software issue, or you may just need a new mouse.
Punteggio 0
1 Commento:
I have a Logitech MX Master and an MX Master 2S. periodically they stutter and hesitate. I think I found the problem. The receiver was plugged into the back of the desktop. Apparently, it is picking up signals from the MB and getting confuse. I put it on the end of an extension cable and so far so good.
da
Aggiungi la tua risposta
mbenji sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 65
Ultimi 30 Giorni: 269
Tutti i Tempi: 29,111
