Salta al contenuto principale
Guide alla riparazione degli accessori per iPhone
34 Domande Visualizza tutte
Removing a hardened glass screen protector?
Hi,
Two friends have hardened glass screen protectors (stick-on) on their phones that have cracked. The phone's screen glass appears fine, it's just the protectors that have cracked, and need to get removed.
Attempting with a fingernail to get underneath a corner of the protector shows that they are very firmly stuck on...
I was thinking about a heat gun - very gently - to soften the adhesive. But I haven't tried it yet, nor anything else.
Anybody have any luck with these ?
If I have to experiment, the good news is that one of the phones in question is about to be replaced anyhow, so it might be a good guinea pig.
Cheers
Neil
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Risposta Più Utile
Use a razor blade to get underneath the screen protector. Once you get it under you can remove with your hands. But I recommend holding the screen down because it sounds like fairly strong adhesive used for the screen protector.
Punteggio 3
1 Commento:
Using a razor blade risks scratching the permanent screen underneath. Bad idea IMHO, unless as a LAST RESORT.
Not to mention the risk of injury if slipping with the razor blade. Perhaps an Xacto knife instead?
da
https://youtu.be/jXmggAgojIY….follow my link to get your answer
Punteggio 0
I generally lift screen protectors with a looped piece of tape to the surface to break the adhesion and lift up so that I can remove a speck of dust from the underside. Using a fingernail or other soft plastic tool to dig underneath a protector risks bending/distorting the protector (bad if you are trying to reuse the protector, and just remove a dust mote). But a soft device/tool is preferrable to a razor blade or other metal that can gouge or scratching the device screen underneath.
If the adhesion is strong, you can move up from weak to stronger types of tape: 3M Scotch tape, packing tape, thin loop of duct tape....
If the protector has become "welded" to the screen, I would use a hair dryer (NOT a heat gun) to warm it up. You might also try the iFixit remover tool that you heat up in a microwave then lay over the screen to warm/soften adhesive.
Some screen protectors are (or were) applied with the help of water. I would NOT apply water directly to the device to try to loosen a protector. Perhaps just use a damp cloth? Try laying a damp cloth over the device, then the iFixit removal tool warmed up, then try in 10-15 minutes. Good luck!
Punteggio 0
Aggiungi la tua risposta
Neil sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 20
Ultimi 7 Giorni: 88
Ultimi 30 Giorni: 312
Tutti i Tempi: 23,345
