Salta al contenuto principale
How do I get my fleece to stop shedding?
My fleece has been washed a few times but still sheds little (pink) bits on everything. I wore it under a different coat and found pink fleece bits all over the other coat. At first I thought it would just stop after washing but sadly it didn't. If anyone has any insight I would be so grateful! Thanks! -kate
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hello Kate,
Patagonia created this iFixit guide detailing specific at-home laundering instructions to reduce fleece shedding.
Hoping this helps out!
Best,
Zach
Punteggio 4
Hi Kate,
You might not be able to stop your fleece from shedding completely, but you can definitely reduce the amount it sheds. Here are a few tips:
1) Use a lint roller.
2) Carefully and slowly use a shaving razor to remove any loose bits.
3) As soon as you notice pilling on your fleece, use this guide to tame any fleece buildup and prevent further shedding.
Hope this helps!
Punteggio 3
Aggiungi la tua risposta
kate sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 68
Ultimi 30 Giorni: 267
Tutti i Tempi: 38,951
