Salta al contenuto principale
Console per videogiochi prodotta da Sony Computer Entertainment; la PlayStation 4 Slim (serie CUH-2000) è un modello sostitutivo più sottile della PS4 originale. Annunciata il 7 settembre 2016.
572 Domande Visualizza tutte
PS4 Slim not turning on after click sound, no beep, no light...
Hello,
I bought a PS4 Slim a few days ago from Amazon and it suddenly stopped working now for some reason.. It clicked and then shutdown and not wanna turn on now.
I live in the UAE and I bought it from Amazon US.. So returning is not that easy and costly.
Soo, wanted to ask if there is an easy fix and could I send it to the local Sony shop ?
Knowing that I've 1 year warranty from Sony.
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
1 Risposta
sounds like it is the hard drive that is no longer working. I would suggest calling sony directly to explain the situation to them, being that the ps4 is still under sony manufacturer warranty it shouldnt matter where you currently live. They will send you a box, ship it to them for a repair, then they will send it back to you.
Punteggio -1
6 Commenti:
The hard drive would do this ? :/
Not the power brick ?????
Its not even turning on.. no errors no nothing.
da
have you tried a different power cable and outlet already?
da
Yep, I did.. I even got a small radio and tried it using the ps4 cable in same outlet
da
ok then back to what i originally said i would call sony directly to have them replace it for you so it doesnt cost you anything out of pocket as it sounds factory defective.
da
It's not the hard drive. The hard drive would never cause that sort of problem.
da
Mostra 1 altro commento
Aggiungi la tua risposta
Ahmad Mamdouh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,982
