One engine not spinning
My drone crashed into the beach.. had a mind of its own I had no control.
Now one of the front engines doesnt spin freely and shut down after I attempt to fly it.
What do I do?
Regards,
Coln
Questa è una buona domanda?
What do I do?
Regards,
Coln
The motor needs to be replaced. A damaged bearing or bent motor shaft IS repairable, only to experienced repair techs, and is near impossible for your average repair novice to achieve.
Unfortunately, DJI has soldered the motor leads onto the logic board. If you don't know how to solder, this makes the repair that much more difficult. iFixit has not created any repair guides for the Mavic Pro, only a teardown. Please know that a teardown is NOT a repair guide, and that any instructions used in a teardown may make it near impossible to put back together.
One of the three tabs the propeller uses to lock in place is probably broken off and lodged into the motor housing. Just remove the propeller and try to remove the broken plastic tab and it should spin freely again. The other option is the motor shaft is bent, or the cylindrical housing is bent disallowing the motor to spin freely. Mine had the tab broken upon impact. good luck to anyone with the problem. The motors are not sold individually [yet] so the option is to replace the arm, between $45 and $80 depending on which arm and the supplier. The process requires soldering the new arm in place.
My Mavic Pro also has a motor suddenly refusing to turn. No crash, no broken off tabs, just not turning, as if locked somehow. Any other ideas?
I fixed my old Mavic Pro. Just needed to work the grains of sand out of the motor. I basically needed to hold it upside down and force it to turn and the grains fell out. It still sounded a bit crunchy in there when I turned it so I did some tapping, vacuuming and more forced turning until the crunchiness was gone. It has worked just fine since.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 14,120
4 Commenti
do I need to ship this to you to fix it?
Are you the the service department for Mavic Pro?
How much is a new motor?
da Colin Wilson
da Chase White
Chase White, you just saved me a whole bunch of headache. I ran my mavic into a wall and the tab broke off inside the motor like you suggested. Had already ordered a replacement arm and motor and bunch of tools to work on it with when I checked your suggestions and found the tab. Back to flying!
da Timothy Trahan
How did you guys remove the tab? I have the same issue - propeller tab broke off inside the little motor but I can't figure out how to get to the broken piece and get it out.
da mat
