Salta al contenuto principale
Il primo modello di iPhone (A1203) con 4, 8 o 16 GB di memoria interna e retro in alluminio. La riparazione potrebbe richiedere alcune saldature e una buona dose di forzature sui componenti.
224 Domande Visualizza tutte
iPhone 1G front panel kit
change iPhone 1G front panel kit
I need that part, and I can't find it on iFixit. It used to be there 3 days ago. Can you help me with the link on iFixit?
Update
Are the 1st gen digitizers the same as the 3G digitizers?
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
4 Risposte
Risposta Più Utile
the digitizer for the 1st generation iphone is connected directly to the lcd screen as well. so its like a combo screen. its not compatible with 2g or 3g because it has different connectors
Punteggio 3
These are all the parts that are available for purchase for the 1st generation iPhone.
As Alex mentioned, the 3G digitizer is not compatible with the 1st generation. Further complicating things, the opening procedure for the phone is very difficult, so you should definitely read through the guide before attempting to replace the display assembly.
Punteggio 2
if the link is gone, it means they run out. its gone mate...
Punteggio 1
1 Commento:
da
i need a front panel for a i phone 1g and a repair kit fot it to
Punteggio 0
Aggiungi la tua risposta
Sameh Mousa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 17
Tutti i Tempi: 11,278
