yes you can provided that the HDD is not damaged ....
To use a Pendrive You will need a 4GB+ USB flash drive for this procedure. then create your bootable USB Disk for the windows Or a windows 8 DVD disk
Then Follow below:
Shut down the computer and reboot into the BIOS by pressing F2 repeatedly immediately after pressing the Power button. Under the "Advanced" tab, set Fast BIOS Mode to Disabled. Under the "Boot" tab, set Secure Boot to Disabled, then OS Mode Selection to CSM OS. Then select "Boot Device Priority" and move USB HDD to the top. and Save your settings then restart
The computer should restart and boot from your USB drive into the Windows installation. Go through the prompts and choose the custom installation option and when it asks where you want to install Windows, click "Drive options (advanced)" and delete all the partitions on the drive and create your desire
The installation will go through and then restart, remove the USB Drive and reinsert it when the Win Logo appeared (If you don't remove the USB disk, you will end up at the initial installation prompt again)
Once the installation is finished you can go to Samsung site and search your ur lap model missing drivers and download them.
TIPs:
reboot into the BIOS and set Fast BIOS Mode back to Enabled (but keep Secure Boot disabled and the OS Mode as CSM OS) and you're done!
Votato
Annulla
Punteggio
19
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
9 Commenti
OLHA ESSE VEDEO Q VAI TE AJUDA https://www.youtube.com/watch?v=LUpH__9B...
da edududujs22
good kee it u
da tesfu
I am also sick of this very very annoing thing which I have seen in GIGABYTE 4th gen non branded systems. if you have attached a usb storage whether it is a usb or external hdd..if you have shutdown ur pc the whenever U starts it ,it tries to boot from that usb which u forgottoen attached in usb port..then U lost ur perfectely running windows,,, why
even you cannot repair ur windows
da Irfan Ikram
shutdown or restarts, gigabyte mobo bios immediately tries to boot from last thing attached with pc..
any usb drive or even a harddrive (hot swapped)for any purpose u hv attached..
iN my case i am a shopkeeper , i recover data for my clients ..
da Irfan Ikram
Muchas gracias, era eso entre a la BIOS y cambie la configuración de arranque, guarde los cambios, reinició y excelente inicio Windows. Fue de mucha ayuda, saludos.
da Antonio Quintero
Mostra altri 4 commenti
