Engine WIll not crank
Craftsman riding mower engine will not crank. Installed new battery and still will not crank.
Questa è una buona domanda?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,692
4 Commenti
Is the mower turning over at all or is it just a dead mower?
da Nathan Wells
turning over backfires thru carb
da allenperkins364
adjusted air gap valves set gap on coil
da allenperkins364
after I changed my blades incorrectly the pgt9000 would not start with the switch. I can jump the solenoid and it will crank and run . I changed the switch and the solenoid , but still have to jump the solenoid. I think there is a relay that blows if the blades aren't on correctly, but I can't find it.
da meriview@aol.com
