My device will not go on and wont charge
My device will not go on and does not show any sign of life even when cinnected to its charger was working ok till thus morning
Questa è una buona domanda?
graeme, check the charging port and make sure it is not bend or has any debris in it. You can clean it with a few puffs of air and some isopropyl alcohol. Make sure that you charger is working properly. Use a multimeter and see what it puts out. After that, you may have to open up your Galaxy and change the battery.
new battery and still won't charge, even losing charge overnight while plugged in. tried different outlets, no help. battery runs out while plugged in! what is going on?
I have seen this due to malware. Try TrendMicro to clean-up your device, if/when you get it to turn on. I've used them for years.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,867
