Salta al contenuto principale
The Sony Cybershot DSC-W55 was released in early in the year 2007. It is upgraded with a 7.2 megapixel camera compared to the previous model's 5.1 camera and has 56mb of internal memory.
24 Domande Visualizza tutte
How to transfer a picture from camera memory onto the SD card?
I took a picture with my camera - not realizing that I didn't have my SD card in. I do not have the cord to transfer photos onto the computer. Is there any way I can put the picture from the camera memory onto the SD card? Is there a transfer option for this on the camera? Worried because now the picture is just "stuck" on my camera :( Help.
Questa è una buona domanda?
Punteggio 12
8 Commenti
the copy option is found when you go into look at your pictures and then hit the "Menu" button. The "Copy" option is then found in there and you will be prompted to choose weather you want so copy from the camera storage to the sd card or vise versa.
da
cannot find a copy option
da
keep scrolling it is several screens down
da
thank you - this information solved a BIG problem for me!
da
I was taking pictures for my high school photography class and had this problem, thank you guys so much!! now I can actually start working on my project lmao, so glad I looked online
da
Mostra altri 3 commenti
Aggiungi un commento
2 Risposte
Soluzione Prescelta
April, I would try to insert a memory card into the camera, then go to camera menu. There should be an option Copy, select copy and transfer images from the internal memory to the memory card. Hope this helps, good luck.
Punteggio 19
19 Commenti:
this is not an answer to your question. sorry, but i just want to say THANK YOU!!!!!!!!! oldturkey03. you just made my night. thought that my pictures were stuck on my camera but thanks to you they are now on my memory stick!
da
lisa, you are welcome:-)
da
i had same issue with my camera. I do not find the "copy" option on my camera. any suggestions?
da
Old Turkey,
Thank you so much for your helpful suggestion. I had the same situation as Lisa with my camera as I forgot to put the SD card in. Thanks, Lisa for asking the question! Old Turkey, it's been over a year since the original post, and I needed this advice tonight. I'm glad that I read your suggestion, and was able to save 24 precious photos that were on my camera!
Gigiann
da
I do not have a "copy" on my camera either. How do I do this?
da
Mostra altri 14 commenti
For anyone who can’t find a “Copy” option, I worked out how to do this on my Olympus TG2 last night, the option I was looking for was “Backup” from the review screen. It then copies all pics on internal to the sd card.
Punteggio 0
3 Commenti:
Hello, i have aproblem with my micro sd card and my LG G6 mobile. Yesyerday I tried to restart my mobile. Suddenly all my pictures and videos on card were gone. Weird. After some minutes of waiting I tried to restart again. But still said damaged sd. I went to storage. Just chose the sd card and this rare lg began to sort of format the card without asking a confirmation. So. I immediately took the card out of lg. Tried in a computer to see if something is on the cardx but hopelessly nothing on it. To try if the card is realy damaged or not i put it again on my lg. Took a pic. That worked. Again out of mobile. Does anyone have solution for me please to gain my pics back? , i still have. Thumbnails of pics on my lg. I would really appreciate if someone could help me on this. Thanks in advance.
da
Will doing this delete the pictures already on the SD card and replace them, or will they just be added on to the card?
da
@aribananas When in doubt, use a card you can risk getting erased inadvertently.
da
Aggiungi la tua risposta
April sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 60
Ultimi 7 Giorni: 265
Ultimi 30 Giorni: 1,163
Tutti i Tempi: 90,364
