Salta al contenuto principale
iPhone 15 Plus Screen Replacement
Cosa ti serve
  1. iPhone 15 Plus Screen Replacement, Prepare your phone for disassembly: passo 1, immagine 1 di 2 iPhone 15 Plus Screen Replacement, Prepare your phone for disassembly: passo 1, immagine 2 di 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Plus Screen Replacement, Tape over any cracks: passo 2, immagine 1 di 2 iPhone 15 Plus Screen Replacement, Tape over any cracks: passo 2, immagine 2 di 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Plus Screen Replacement, Mark your opening picks: passo 3, immagine 1 di 3 iPhone 15 Plus Screen Replacement, Mark your opening picks: passo 3, immagine 2 di 3 iPhone 15 Plus Screen Replacement, Mark your opening picks: passo 3, immagine 3 di 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 15 Plus Screen Replacement, Remove the pentalobe screws: passo 4, immagine 1 di 1
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Plus Screen Replacement, Secure the back glass: passo 5, immagine 1 di 3 iPhone 15 Plus Screen Replacement, Secure the back glass: passo 5, immagine 2 di 3 iPhone 15 Plus Screen Replacement, Secure the back glass: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Anti-Clamp
    $24.95
    Compra
    • The next four steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open the screen, you need to secure the back glass with tape. You can also check out the full instructions on how to use this tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the back glass to secure it.
  6. iPhone 15 Plus Screen Replacement, Secure an Anti-Clamp: passo 6, immagine 1 di 3 iPhone 15 Plus Screen Replacement, Secure an Anti-Clamp: passo 6, immagine 2 di 3 iPhone 15 Plus Screen Replacement, Secure an Anti-Clamp: passo 6, immagine 3 di 3
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the screen facing up, slide the arms over the left edge of your phone, with one suction cup on the screen and the other on the back glass. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  7. iPhone 15 Plus Screen Replacement, Create a gap under the screen: passo 7, immagine 1 di 3 iPhone 15 Plus Screen Replacement, Create a gap under the screen: passo 7, immagine 2 di 3 iPhone 15 Plus Screen Replacement, Create a gap under the screen: passo 7, immagine 3 di 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they tend to slip, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may use your hands to clean the suction cups and warm them up to help them stick.
  8. iPhone 15 Plus Screen Replacement, Insert an opening pick: passo 8, immagine 1 di 3 iPhone 15 Plus Screen Replacement, Insert an opening pick: passo 8, immagine 2 di 3 iPhone 15 Plus Screen Replacement, Insert an opening pick: passo 8, immagine 3 di 3
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the screen and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti-Clamp and time do the work for you.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  9. iPhone 15 Plus Screen Replacement, Heat the bottom edge: passo 9, immagine 1 di 1
  10. iPhone 15 Plus Screen Replacement, Insert an opening pick: passo 10, immagine 1 di 3 iPhone 15 Plus Screen Replacement, Insert an opening pick: passo 10, immagine 2 di 3 iPhone 15 Plus Screen Replacement, Insert an opening pick: passo 10, immagine 3 di 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  11. iPhone 15 Plus Screen Replacement, Screen information: passo 11, immagine 1 di 2 iPhone 15 Plus Screen Replacement, Screen information: passo 11, immagine 2 di 2
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone, one just above the mute switch, and the other about halfway between the volume down button and the bottom of the phone.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  12. iPhone 15 Plus Screen Replacement, Separate the bottom edge adhesive: passo 12, immagine 1 di 3 iPhone 15 Plus Screen Replacement, Separate the bottom edge adhesive: passo 12, immagine 2 di 3 iPhone 15 Plus Screen Replacement, Separate the bottom edge adhesive: passo 12, immagine 3 di 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  13. iPhone 15 Plus Screen Replacement, Heat the right edge: passo 13, immagine 1 di 1
    • Heat the right edge of the screen until it's hot to the touch.
  14. iPhone 15 Plus Screen Replacement, Separate the right edge adhesive: passo 14, immagine 1 di 3 iPhone 15 Plus Screen Replacement, Separate the right edge adhesive: passo 14, immagine 2 di 3 iPhone 15 Plus Screen Replacement, Separate the right edge adhesive: passo 14, immagine 3 di 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Insert a second opening pick to the right of the first one.
    • Slide the pick along the right edge of the screen to release the clips and separate the adhesive securing it.
  15. iPhone 15 Plus Screen Replacement, Heat the top edge: passo 15, immagine 1 di 1
    • Heat the top edge of the screen until it's hot to the touch.
  16. iPhone 15 Plus Screen Replacement, Separate the top edge adhesive: passo 16, immagine 1 di 2 iPhone 15 Plus Screen Replacement, Separate the top edge adhesive: passo 16, immagine 2 di 2
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Insert a third opening pick in the top right corner and slide it along the top edge to release the two clips and adhesive securing it.
  17. iPhone 15 Plus Screen Replacement, Heat the left edge: passo 17, immagine 1 di 1
    • Heat the left edge of the screen until it's hot to the touch.
  18. iPhone 15 Plus Screen Replacement, Separate the left edge adhesive: passo 18, immagine 1 di 3 iPhone 15 Plus Screen Replacement, Separate the left edge adhesive: passo 18, immagine 2 di 3 iPhone 15 Plus Screen Replacement, Separate the left edge adhesive: passo 18, immagine 3 di 3
    • Don't insert your pick deeper than 3 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Slide your pick around the top left corner of the screen and along the left edge to release the clips and separate the adhesive securing it.
  19. iPhone 15 Plus Screen Replacement, Swing open the screen: passo 19, immagine 1 di 2 iPhone 15 Plus Screen Replacement, Swing open the screen: passo 19, immagine 2 di 2
    • Gently swing open the screen over the left edge of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the screen against a box or similar object so it doesn't strain the cables.
  20. iPhone 15 Plus Screen Replacement, Unfasten the front sensor connector cover: passo 20, immagine 1 di 1
    • Use a tri-point Y000 driver to remove the 0.9 mm‑long screw securing the front sensor connector cover.
  21. iPhone 15 Plus Screen Replacement, Remove the cover: passo 21, immagine 1 di 3 iPhone 15 Plus Screen Replacement, Remove the cover: passo 21, immagine 2 di 3 iPhone 15 Plus Screen Replacement, Remove the cover: passo 21, immagine 3 di 3
    Compra
    • Use tweezers to lift the cover to a 90-degree angle.
    • Unhook the cover from its slot in the logic board.
    • Remove the cover.
    • During reassembly, insert the cover at a 90-degree angle to re-engage the hook before laying it flat against the press connector.
  22. iPhone 15 Plus Screen Replacement, Disconnect the front sensor: passo 22, immagine 1 di 2 iPhone 15 Plus Screen Replacement, Disconnect the front sensor: passo 22, immagine 2 di 2
    • Use the tip of an opening pick to pry up and disconnect the front sensor press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
  23. iPhone 15 Plus Screen Replacement, Unfasten the screen connector cover: passo 23, immagine 1 di 1
    • Use your tri-point Y000 driver to remove the 0.9 mm‑long screw securing the screen connector cover.
  24. iPhone 15 Plus Screen Replacement, Remove the cover: passo 24, immagine 1 di 3 iPhone 15 Plus Screen Replacement, Remove the cover: passo 24, immagine 2 di 3 iPhone 15 Plus Screen Replacement, Remove the cover: passo 24, immagine 3 di 3
    • Use tweezers to lift the cover and unlatch it from its hook on the logic board.
    • Remove the cover.
  25. iPhone 15 Plus Screen Replacement, Disconnect the screen: passo 25, immagine 1 di 2 iPhone 15 Plus Screen Replacement, Disconnect the screen: passo 25, immagine 2 di 2
    • Use the tip of an opening pick to pry up and disconnect the screen press connector.
  26. iPhone 15 Plus Screen Replacement, Remove the screen: passo 26, immagine 1 di 3 iPhone 15 Plus Screen Replacement, Remove the screen: passo 26, immagine 2 di 3 iPhone 15 Plus Screen Replacement, Remove the screen: passo 26, immagine 3 di 3
    • Remove the screen.
    • During reassembly, use this guide to reapply adhesive and install your new screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
Conclusione
To reassemble your phone, follow this guide to reapply adhesive and install your screen.
Clay Eickemeyer
Membro da: 09/19/22
67.432 Reputazione
453 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.437 Guide realizzate
2 Commenti
No link for screen?
Josh Clayman - Replica
Battery still plugged in? You would need to take the back glass also
Smarterthanyou - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 83
Ultimi 30 Giorni: 328
Tutti i Tempi: 1,620
