Salta al contenuto principale
How to fix a blown heater element in a Toaster
jon
jon e 2 altri collaboratori
Ultimo aggiornamento il 7 giu 2019
1 ora
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
The blown element stops the toaster working, but the wires can be rejoined over the blown section, with very little detrimental effect. See this fix in this video guide
Cosa ti serve
Panoramica Video
    • Insert wisdom here.
    • how to fix a toaster
Conclusione
Not too difficult, you need patience though.
Altre 4 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
jon
Membro da: 05/15/16
3.102 Reputazione
22 Guide realizzate
2Commenti sulla guida
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
mitchell.drury - Replica
Mine is still working even after all this time (over 2 years ago). If your heater element is still connected (low resistance) then the fault is somewhere else. Trace the resistance of connections back through the switch to the plug to find the fault.
jon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 79
Tutti i Tempi: 26,401
