Salta al contenuto principale
How to Discharge a Capacitor in Large Machinery
Cosa ti serve
  1. How to Discharge a Capacitor in Large Machinery, Create a capacitor discharge tool: passo 1, immagine 1 di 3 How to Discharge a Capacitor in Large Machinery, Create a capacitor discharge tool: passo 1, immagine 2 di 3 How to Discharge a Capacitor in Large Machinery, Create a capacitor discharge tool: passo 1, immagine 3 di 3
    • Inspect your capacitor and note the following:
    • The voltage rating of either your capacitor or the device
    • Where the terminals are located
    • Attach two wires to an incandescent lightbulb—making sure the bulb's voltage rating is greater or equal to the capacitor's.
  2. How to Discharge a Capacitor in Large Machinery, Discharge the capacitor: passo 2, immagine 1 di 2 How to Discharge a Capacitor in Large Machinery, Discharge the capacitor: passo 2, immagine 2 di 2
    • Don't touch the two wire leads together during this step, as this could short circuit the capacitor.
    • Lay one wire lead on the head of the terminal.
    • While holding the lead in place, lay the other wire lead on the opposite terminal to complete the circuit.
    • Hold this position for a few seconds or until the lightbulb completely darkens.
  3. How to Discharge a Capacitor in Large Machinery, Check with a multimeter: passo 3, immagine 1 di 1
    • If you have a multimeter, you can check to see if the capacitor is fully drained.
    • Set the meter to its DC voltage measuring mode and measure across the terminals.
    • Any value under 10 volts means your capacitor is sufficiently drained.
Conclusione
For other general electronics skills, click here.
Altre 6 persone hanno completato questa guida.
Alex Diaz-Kokaisl
Membro da: 01/16/22
125.789 Reputazione
592 Guide realizzate
iFixit Membro di iFixit
Staff
137 Membri
17.524 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 58
Ultimi 30 Giorni: 222
Tutti i Tempi: 1,485
