Salta al contenuto principale
How To Repair a Faulty Switch on a Trio-60 Keyboard
Cosa ti serve
  1. How To Repair a Faulty Switch on a  Trio-60 Keyboard, Key Switch: passo 1, immagine 1 di 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard, Key Switch: passo 1, immagine 2 di 2
    • Unplug the keyboard
  2. How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 2, immagine 1 di 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 2, immagine 2 di 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 2, immagine 3 di 3
    • Use a keycap puller to remove the keycaps "3", "4", "0'", "-", "Caps Lock", "enter" and both "alt" keys to gain access to screws.
    • Place the keycap puller straight over the keycap, so that the wires are under the keycap and pull straight up.
    • It may require slight angling and pressure to remove the keycap.
  3. How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 3, immagine 1 di 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 3, immagine 2 di 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 3, immagine 3 di 3
    • Remove six 4.0 mm screws with a Phillips #0 screwdriver.
    • Consider using a magnetized screwdriver or magnet to remove screws, or leave them in the chassis.
  4. How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 4, immagine 1 di 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 4, immagine 2 di 2
    • Remove the top chassis (metal cover) by lifting straight up and off of the keyboard.
  5. How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 5, immagine 1 di 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 5, immagine 2 di 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 5, immagine 3 di 3
    • Gently flip the plate and PCB towards the back of the case, so that it lies upside down behind the case.
    • Ensure not to pull on or twist the keyboard as it's attached to a cable and could cause damage.
  6. How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 6, immagine 1 di 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 6, immagine 2 di 2
    • Use your fingers or a spudger to remove the JST cable on the end of the circuit board.
  7. How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 7, immagine 1 di 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 7, immagine 2 di 2
    • Make sure to desolder in a well-ventilated area, as the smoke released from the boiling flux is toxic. Placing a small fan near and facing away from your soldering area is recommended.
    • Heat the solder until it appears liquified.
    • Use your preferred sucking tool of choice to remove the solder (an electric desolder is recommended).
    • Desolder both points for each switch you are removing.
    • The location of desoldering may vary depending on which switches are faulty.
  8. How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 8, immagine 1 di 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 8, immagine 2 di 2
    • Use a switch puller or your fingers to remove the faulty switch.
  9. How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 9, immagine 1 di 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 9, immagine 2 di 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 9, immagine 3 di 3
    • If a pin is bent, flatten it with pliers so that it is perpendicular to the switch.
    • If the pin is not bent, there may be electronic issues causing switch malfunction that will not be covered in this guide.
  10. How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 10, immagine 1 di 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 10, immagine 2 di 2
    • Place the new or repaired switch straight down until it is firmly locked into plate.
  11. How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 11, immagine 1 di 1
    • Solder the switch and test the keyboard to ensure it functions correctly.
    • Make sure to solder in a well-ventilated area, as the smoke released from the boiling flux is toxic. Placing a small fan near and facing away from your soldering area is recommended.
  12. How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 12, immagine 1 di 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard: passo 12, immagine 2 di 2
    • Optionally apply isopropyl alcohol to Q-tip and clean flux residue from solder joints.
Conclusione
Chase Keighley
Membro da: 04/19/23
205 Reputazione
1 Guida realizzata
UC Davis, Team 1-3, Morris Spring 2023 Membro di UC Davis, Team 1-3, Morris Spring 2023
UCD-MORRIS-S23S1G3
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 216
