Wiki con Collaborazione Studenti
Un fantastico team di studenti del nostro programma educativo ha realizzato questo wiki.
Camera won’t turn on
If your camera does not turn on, or respond to the power button in anyway, such as the screen stays off, the lights stay off, or the camera doesn’t respond in general, check the following:
Drained/bad battery
If the adapter is plugged in, the light should turn on. If the light does not turn on, replace your adapter. If the adapter light turns on, and the battery still does not charge, replace your battery.
Broken or Damaged Hard Drive
If it is not the battery, then it is possible you have a faulty hard drive.
Camera will not charge
If your camera refuses to charge, please check the following:
Battery Adapter
Make sure the battery adapter is lighting up when it is plugged in. If it is not, the battery adaptor is broken, and needs to be replaced.
Damaged or Broken Battery
If the battery adapter is working, but it still won’t charge. Then the battery is damaged or broken, and needs to be replaced.
Camera is not recording
If your camera is not recording, check the following:
Camera is running too hot
It is possible the camera’s temperature is too hot, and it needs to sit while turned off for several hours (at least 3) to cool down.
Hard Drive is Full
It is possible the hard drive is full, and some of the content on your hard drive should be moved to your computer or deleted.
If you remove or delete the content on your hard drive, and your camera still doesn’t record, then it is possible your hard drive is damaged and needs to be replaced.
The recordings have no sound
If your camera is successfully recording video, but that video has no sound, please check the following:
The camera temperature could be too high
if that is the case, let your camera sit while turned off for several (at least 3) hours to cool.
Drained/bad battery
Your camera’s microphone may have been damaged
If it is not any of the above, then it is possible that, and it needs to be replaced.
Camera is not registering with a computer
If your camera is plugged into your computer, but it is not registering with the computer itself, please check the following:
Drained/bad battery
It is possible the USB cable is damaged
Try plugging it in with a different USB cable (if you have one).
It is possible the USB port on your computer is broken
Try plugging your camera into a different computer, and see if it registers there.
Damaged USB on Camera
It is possible that the USB ports on the camera are malfunctioning, and may need to be replaced.
It is also possible that the hard drive is malfunctioning, and needs to be replaced.
Camera registers on the computer, but the videos are not showing up
If your camera is plugged into your computer, but the videos and images taken with your camera are not showing up on your computer, please check the following:
Deleted Videos
The images on your computer were somehow deleted, most likely by human error.
If it happens multiple times, then it most likely means your hard drive is broken or damaged, and it needs to be replaced.
Blurry picture/recording, or there are wavy lines on the pictures and recordings
If the pictures and recordings taken are blurry, or appear to be wavy, please check the following:
Make sure the camera’s auto-focus is turned on
You can find the auto-turn settings under the options menu.
Broken or Damaged Lense
It is also possible your camera has a cracked or broken lense, and needs to be replaced.
Broken or Damaged Flex Cable
If your camera has wavy lines on the images it has taken or recorded, then the flex cable has been broken or damaged and needs to be replaced.
0 Commenti
