Camera Lens Does Not Retract
The screen error message “Turn the power off and on again” may accompany the problem. Possible causes for a stuck lens is power failure, dropping the camera while the lens is extended, or debris collected inside the lens system. The camera may require disassembly to repair the extend mechanism if these troubleshooting methods do not help.
Power Failure
Remove the battery from the camera and replace with fully charged battery or a replacement Sony approved battery. Reinstall the battery and press POWER to see if it turns on.
Extending Mechanism Is Crooked or Out of Place
Place index finger on the crooked part of the extender. Place thumb on the camera opposite of your index finger. Pull the extender with your index finger until you hear an audible click noise. The guide pins should now be aligned to allow the extending mechanism to work.
Debris in The Extending Mechanism
Hold the camera upside down with the lens facing downward. Place the corner end of a piece of paper inside the extending mechanism of the stuck lens. Slowly go full circle with the piece of paper until it encompasses the full diameter of the extending mechanism of the lens. This should dislodge any stuck debris that may have been trapped inside during operation.
Camera Does Not Turn On
This problem relates to battery power not being received by the camera.
Charge Camera Battery
The camera battery may require charging. Plug camera into the charging cable and allow it to recharge to full. Once this is done, press the POWER button on the camera and see if it turns on.
Battery is Dead
Over time, camera batteries may be unable to hold a charge after years of use. Replace the camera battery with an approved Sony battery and recharge. Reinstall new battery and press POWER to see if the camera turns on.
Dirty Contacts
Dust and dirt may have inadvertently collected inside the battery compartment on the terminal connections which may cause the camera to not turn on. Remove the camera battery and set aside. Using a Q-tip, wipe the battery contact points inside the compartment. Use the same Q-tip and wipe the terminals on the battery itself. Reinstall battery and press POWER to test the camera.
SD Card Door does not Lock
When trying to insert SD card back into the memory slot, the door does not lock into place.
SD Card Does Not Fully Insert
Fold a piece of paper into a small square. Hold the paper over the SD card slot and attempt to close the door. The sheet of paper should force the memory card down far enough for the door to lock and create an audible click noise.
Debris Inside SD Card Slot
Using a flashlight, inspect the SD card slot and look for debris. If debris is found, attempt to dislodge it with a hairpin and remove from the slot. Reinstall SD card and ensure it locks into place.
Camera HDMI Feature Does Not Display Images on External Screen
Pictures from camera do not display on external screen when using an HDMI cable.
Camera's HDMI Feature Does Not Work
Check HDMI settings on the camera and ensure it is set to be used with an external screen such as a television or computer monitor.
HDMI Will Not Display on External Screen while Shooting Videos
Ensure your television is set to the proper HDMI port the camera is plugged in. Enable HDMI viewing on the camera to see if pictures show on your television screen. If no images appear, plug HDMI cable into another HDMI plug on the television and repeat the process. If an image does not appear again, replace defective HDMI cable.
Battery Does Not Hold a Charge
This section is to help troubleshoot battery charging problems.
Fast Draining Lithium Ion Battery
If the battery drains quickly while in use, perform the following battery power cycle steps.
Completely drain the battery by allowing it to stay powered until exhausted. Test battery power levels by attempting to turn it on by pressing POWER. If the camera does not turn on, then the battery is fully drained. Place camera on the charger for 48 hours to complete a full battery power cycle.
Dead Lithium Ion Battery
If the battery is unable to hold a charge, replace with an approved Sony battery.
2 Commenti
Camera Does Not Turn On, Stopped working through the day and will not turn back on, checked that the battery had a full charge, and swapped with another battery, checked the contacts, just will not switch on, is this going to be a warranty issue.
Mark Ingram - Replica
Flash of my HX9V is not working properly. It actaully popus up but doesn’t throw the white light. I got it checked in the Sony Service center and this is what they suggested me to change: http://prntscr.com/qidtm4 Can anyone identity these two parts and from where I can get them? Also, any repaid guide available on how to change the flash?
Raj - Replica
