Wiki con Collaborazione Studenti
Un fantastico team di studenti del nostro programma educativo ha realizzato questo wiki.
If you are you having issues with your Shark Navigator Lift-Away Pro NV356E V5 not turning on, there are many things that can be causing this. In this guide, you will be able to target the issue and get it fixed.
Power Switch Is Off
If the vacuum's power switch is not turned on it will not work. Check to ensure the switch is on the "I" position.
Incorrectly Plugged In
The vacuum may not be powering on because it is not plugged in correctly. Look to see if the plug is fully placed into the power outlet. If it is properly plugged in and still not working, there may be an issue with the power outlet itself. Plug in another cord to check that the outlet works.
Overheating
The Shark Navigator Lift-Away Pro may overheat due to clogged filters, blockages, or prolonged use. Turn off the vacuum and let it cool for at least 45 minutes before troubleshooting.
Motor Thermostat Needs to be Reset
When your vacuum has overheated, the motor automatically turns the unit off. This means the motor will need to be reset. To reset the motor follow these steps:
- Move the On/Off switch to the “O” (Off) position.
- Unplug the vacuum.
- Empty the dust cup and clean the filters.
- Check for blockages in hose and accessories.
- Allow the unit to cool for at least 45 minutes.
- Plug in the vacuum.
- Turn the On/Off switch to the “I” (On) position to restart the vacuum.
0 Commenti
