Wiki con Collaborazione Studenti
Un fantastico team di studenti del nostro programma educativo ha realizzato questo wiki.
Keyboard freezes
If the keyboard will become completely unresponsive, none of the individual keys work, and none of the key combinations work (for example CTRL - ALT - DELETE)
Option 1:
First try uninstalling the keyboard driver. To do this: first go to control panel and hit the start key. In the search toolbar search “control panel”. Under “Programs” select “control panel”. In “control panel” select “device manager” under the “devices and printers” page. In device manager hit the “keyboards” tab to view keyboards, and double click on the standard keyboard. Go to the “Driver” tab and select “Uninstall” and follow the given instructions to uninstall the driver. Restart the computer (yes without reinstalling the driver) and when the computer restarts it should reinstall the needed driver itself. Test the keyboard to verify that this option worked.
Option 2:
Find a functional external keyboard (Like one used with a desktop computer. Avoid use a gaming keyboard as this will install its own set of programs and drivers). Plug external keyboard into USB port. If prompted decline any options to install divers. Test the function of the external keyboard. If the external keyboard works without any hitches, then the issue is with the physical keyboard. If this option does not work see keyboard replacement guide.
Touch Screen is Not Precise (calibrated)
Option 1: Clean the Surface of the Screen
Turn the computer off completely, using either the power button or the start menu. Using a generic Screen/TV surface cleaner, apply a thin coating of the product to the surface of the screen. Next, using a lint free cloth, wipe the monitor clean, making sure to remove any liquid remaining on the screen.
Option 2: Re-Calibrate the Display
Open the control panel. Navigate to the “Hardware and Sound” menu entry. Under the “Tablet PC Settings” menu entry, select “Calibrate the Screen for pen or touch input”. Navigate to the “Display” tab. Click the “Calibrate” button, then select the appropriate desire calibration target. Next, read the on-screen prompt, and begin tapping the crosshairs as they appear in the corners of the screen. After completing the calibration prompts, click “Save Data” to retain and apply the calibration data generated.Repeat until satisfied with touch screen precision.
Repeated BIOS Setup on Startup of Devices
Option 1: Boot an OS from bootable drive (CD or flash drive). Preferable same OS as already on device. Follow instructions on boot up screen. Install OS onto device. If prompted for product key, enter product key. Agree to License Agreements. Click 'No' to lossing all files if you want to keep your files. Click next when on set-up screen, then Ok for window popup. Wait for install. Once OS is installed computer should boot back up with OS just installed and all files still intact.
Option 2: Power off the laptop. Power on the laptop. As soon as you see the rotating loading circle, press and hold the Power Button until the computer shuts off. Repeat this process a few times until you see the "Preparing Automatic Repair" screen. Now you want to let the laptop boot to the "Automatic Repair" screen. Click "Advanced Options" and then select "Troubleshoot". Here you want to select "Refresh your PC", if you do not wish to erase data, or "Reset your PC" to erase all data and restore your system. From here just follow the screen instructions until the recovery is completed.
Touchpad Freezes
If your touchpad doesn't work or is not functioning correctly, it may be because the driver is not installed or did not install correctly. To check your driver, follow the steps below,
- Open Samsung Update by clicking on app icon on your Desktop or in Start Menu.
- Click on All Software from left side menu in Samsung Update
- Locate Touchpad Driver. If Install appears, click install. If Install does not appear, your driver has already been installed.
If you have connected a mouse to your PC and your touchpad isn't working, this is because the option to disable the touchpad has been set. To enable the touchpad while a mouse is attached, follow the steps below.
- Open Settings from Action Center
- Select Devices.
- Select Mouse & touchpad on left, scroll down to bottom, and then click on Additional mouse options.
- Click on Touchpad or Device Settings tab
- Click on Settings... or Options... to access touchpad settings.
- If box next to Disable when external pointing device is attached is checked, uncheck it.
If the problem is that the pointer is moving around the screen erratically, make sure that the touchpad is not being touched while using the keyboard. If you find that you are touching the keyboard while typing, you may want to use an external mouse and disable the touchpad by pressing the Fn+F5 keys.
Wireless connection drops
Option 1: Go to "Control Panel". Next go to "Network and Internet" and then "Network and Sharing". Now click on "Manage Wireless Networks". On this screen, remove all wireless connections by "right clicking" on it and select "Remove network" from the drop down menu. After doing this, close the open windows and reboot the computer. Once the computer is fully reloaded, scan for the "WiFi networks". Click on the available network that you want to access and select "connect". It takes a moment, but then you will be asked to give a password for your WiFi connection. Type in the password and click the "connect" button.
Option 2: Go to "Settings". Click on "Network & Security" and then click on "WiFi". Now click "Manage known networks". Select the WiFi connection you want to remove. Click the "Forget" button. After doing this, close the open windows and reboot the computer. Once the computer is fully reloaded again go to "Settings". Click on "Network & Security" and then click on "WiFi" Now click "Manage known networks". Click "Add a new network" and enter the network name. Using the drop-down menu, select the "network security type". Check the "Connect automatically" option. Now check the "Connect even if the network is not broadcasting" option and click "Save".
Battery only charges to 80%
If the battery on your computer is only charging to 80% this is likely because Battery Life Extender is turned on. Battery Life Extender sets the maximum battery charge level to 80% in order to extend the life of your battery. To turn this function off and charge your Samsung laptop battery to 100% follow the steps below.
Windows 8
Open Settings from the Start Screen or your desktop. If you do not have Settings installed click here for instructions on installing it. In the Settings window, go to Power Management. Click the Battery Life Extender tab. On the Battery Life Extender window, slide the slider to Off. Battery Life Extender is now turned off.
Windows 7
In order to turn Battery Life Extender off in Windows 7, you will need to access the BIOS. To access the BIOS and turn this function off, follow the steps below. Turn your computer on. When you see the Samsung logo appear, press the F2 key repeatedly and the BIOS screen will appear. Use the right arrow key on your keyboard to move to the Advanced tab in the BIOS. Use the down arrow key to highlight Battery Life Cycle Extension, then press Enter. Use the up/down arrow keys to select Disabled and then press Enter. Press the F10 key to save and exit. Your computer will now start up and Battery Life Extender is disabled
Laptop restarts randomly
Note: If this problem started after an update (or system reinstall), please make sure the laptop is not connected to the internet in any way before you use the following instructions.
Option 1:
NOTE: You will need to get into the Advanced Options in order to get the Refresh Option. This choice will keep your data, but any programs installed will be lost.
Do not do a Reset as that will wipe all data you have on the laptop.
Battery does not charge
Connect the AC Adapter to your notebook and to a wall outlet. Make sure the wall outlet you are using is working properly by testing it with another electronic device, such as a desk lamp. Check the LED light on the notebook. If the battery is charging, the LED on the notebook will light up red. If the LED does not light up red, the battery is not charging (try to test the notebook with another compatible AC adapter). Service is required. Try to turn on the notebook. If the notebook turns on, the problem may be caused by the battery. If the notebook does not turn on, there may be a problem with the Battery or AC adapter.
0 Commenti
