Wiki con Collaborazione Studenti
Un fantastico team di studenti del nostro programma educativo ha realizzato questo wiki.
If your Philips Somneo light isn't turning on or is not getting bright enough when the Philips Somneo's alarm goes off, use this troubleshooting guide to help diagnose why.
Light Setting Turned Off
Check your Philips Somneo alarm settings. Then verify that the light is activated for when your alarm goes off.
Brightness Too Low
Check your Philips Somneo light settings. Then verify that your light setting is bright enough so that it is noticeable.
Device is Frozen
In order to perform a hard reset, the reset button can be found behind the device. When the reset button is located, use a small tool to press the small reset button and hold for a couple of seconds.
0 Commenti
