Studente al lavoro
Questa wiki è in lavorazione da parte di studenti laboriosi.
Motorola Moto G Stylus 5G 2023 Wallpaper Resets Unexpectedly
When the device resets after a crash, the wallpaper will revert to the default design. Follow these steps to fix wallpaper resets.
It can be caused by a software glitch, a third-party app with a rotating wallpaper feature, or the “daily wallpaper” setting. To fix this:
Faulty "Daily Wallpaper" Setting
- Hold and press on a blank area of your home screen
- Tap Wallpapers & style or Wallpapers
- Look for any wallpaper category with a Daily or automatic-changing option, and make sure it is not selected
- Choose an unmoving wallpaper from photos or the wallpapers the phone provides
Corrupted System Cache
- Go to Settings > Apps
- Tap the icon with 3 lines or dots and select Show System Apps
- Search for Wallpaper
- Tap on each wallpaper application and then go to Storage & Cache
- Select Clear Cache and Clear Data
- Restart the phone and set the wallpaper again
Conflicts from Third-Party Apps
- Identify the app that may be causing this issue
- Check app settings to confirm that automatic wallpaper updates are turned off
- Reboot the phone into Safe Mode, which temporarily disables third-party apps
- Press and hold the power button, and tap the Power Off button
- Click the OK button to boot into Safe Mode. If the issue is resolved, a third-party app is likely causing the problem.
0 Commenti
