Studente al lavoro
Questa wiki è in lavorazione da parte di studenti laboriosi.
Motorola Moto G Stylus 5G 2023 Device Will Not Hold a Charge
The device refuses to hold a charge even after proper cleaning of the charging port. Follow these steps to fix any issues relating to the charging port.
Clogged Charging Port
- Check that the Charging Port and Charging Cord are Both Clear of Debris.
- If unclear, use a small pin or Q-tip to remove debris.
- If the charging port and charging cord are clear of all debris, then the problem could be that a software update is needed.
Out-dated Software
- Go to Settings > System Updates to check if any new updates are available for the phone.
Device Needs a Restart
- Hold down the power button and volume button.
- Hold and wait until the pop-up menu appears, and press “Restart”.
Power-draining Apps
- Go to Settings > Battery> Battery Usage to locate apps that are causing high power loss
- Click App and touch the app or feature that uses a lot of power.
- Once clicked, go to App settings > Either Force Stop App or Restrict Battery Usage.
If the device continues not to hold a charge, the battery is degraded and needs a repair or replacement.
0 Commenti
