Does your Insignia NS-24ER310NA17 television turn on but not show any image on the screen? Insignia NS-24ER310NA17 televisions are susceptible to a range of problems that can cause them to stop displaying images. Check the following causes to identify and solve the problem.
Cause 1: Faulty Light Sensor
If the television’s screen is black but you can hear audio playing, try shining a bright light on the screen. If no image can be seen, the television’s light sensor may be faulty. Use the Insignia NS-24ER310NA17 Infrared Sensor Replacement Guide to replace the television’s faulty infrared light sensor.
Cause 2: Faulty Screen
If you shine a bright light on the television’s screen and an image can be seen, the screen’s lighting element is likely faulty. Insignia televisions are self-contained units, so most small parts cannot be replaced. So, if the screen’s lighting element is faulty, the entire screen will need to be replaced. Use the Insignia NS-24ER310NA17 Screen Replacement Guide to replace the television’s faulty screen.
Questions other people have asked about this
- Insignia NS-39D400NA screen problem?
- Insignia TV picture is blank
- Insignia NS-50DR710NA17 lights up, back picture doesn't come on
0 Commenti
