Wiki con Collaborazione Studenti
Un fantastico team di studenti del nostro programma educativo ha realizzato questo wiki.
Is your Hover-1 All-Star failing to power on after pressing the power button, or is completely unresponsive? Use this troubleshooting guide to help diagnose why.
Battery is Not Charged
Ensure that the battery is charged by plugging the Hover-1 using the power cord that it comes with and insure that the charging light illuminates. Wait for the light to turn from red to green then try to power it on again. If the charging light does not illuminate, refer to our next page addressing charging.
Power Button is Damaged/Dirty:
The power button could be damaged or dirty if after making sure the hover-1 has been charged properly it still fails to power on. First try to clean the areas around the power button with a paper towel or a brush. If it still does not work it may need to be replaced. See guide on button replacement (link to future guide).
Loose or Disconnected Internal Wiring:
Lose wiring could be very likely with some of the abuse that these can take. Disassemble the outer casing and look carefully for loose or damaged wires, See guide on disassembly (link to future guide). If you find any connections that have been broken or disconnected connect them back to their original positions and try to power it on again.
0 Commenti
