Wiki con Collaborazione Studenti
Un fantastico team di studenti del nostro programma educativo ha realizzato questo wiki.
Landing Problems
The legs of the GHOSTDRONE come off when landing.
Weak Propellers
The GHOSTDRONE's propellers come off or don't spin fast enough.
Uncalibrated Compass
Your GHOSTDRONE doesn't recognize Cardinal Directions.
Faulty Gimbal
The Gimbal that holds the camera on the GHOSTDRONE comes off or doesn't hold the camera.
Battery Issues
Your GHOSTDRONE displays ERR1 or ERR4 message on screen.
Frozen Battery
If your Ehang GHOSTDRONE won't turn on or displays ERR4 on the display screen, replace the battery or send it back to manufacturer.
Battery Glitch
If your Ehang GHOSTDONE is frozen on an ERR1 message on the display screen, reboot the device. Alternatively, take the battery out and reinsert in.
Calibration Issue
Your GHOSTDONE doesn't calibrate the drone compass with your phone.
Faulty Gimbal
The gimbal on your GHOSTDRONE won't stabilize
Weight Adjust Interrupted
If the gimbal on your GHOSTDRONE won't stabilize, make sure the camera is attached to the gimbal before you power the gimbal on.
Loose Gimbal
The gimbal on your GHOSTDRONE doesn't hold your camera securely.
12 Commenti
I can't get the goggles to connect to the camera, any suggestions?
Ryan Brenner - Replica
for the loose camera I made a little spacer that goes under the locking ring that took up the little bit of play between the camera and the holding bracket.
rich scheurich - Replica
for the loose camera in the gimbal, i made a spacer that goes underneath the locking ring that took up the gap between the camera and the gimbal bracket. Holds much more securely now.
compass error. I go to settings, calbrate compass, strange thing that at the step1 it is automaticly says completed even if I dont touch the drone, then I do the step2 step3, it says completed,ready to fly, i go back to app, take off, gives me compass error, asks me to calibrate compass.
any suggestion?
thanx
Janez Sabo - Replica
My ghost drone 2.0 aerial gives a message when trying tomcalibrate the camera: camera gimbal not detected. How can I overcome this issue?
davidstewart25 - Replica
