Studente al lavoro
Questa wiki è in lavorazione da parte di studenti laboriosi.
Dell XPS 13 9370 Battery Overheating
The laptop's battery or bottom chassis becomes unusually hot during use, sometimes triggering thermal warning or automatic shutdowns. Users may notice the laptop is uncomfortable to touch and performance may slow down.
Dust or Blocked Air Vents
Dust builds up or blocked air vents can prevent proper airflow and can cause the battery to heat up. To resolve this, turn off and unplug the device, then remove the back cover using a screwdriver. Carefully clean the fans and vents. Once clean, reassemble the laptop and check if the temperature is back to normal.
Faulty Battery or Circuit
The battery or circuit may be the cause of the overheating. Check the battery's health by running a diagnostic test in the BIOS. If the test shows poor battery health, it should be replaced with a Dell certified battery. However, if the battery still overheats the issue could be a faulty charging circuit in the motherboard.
0 Commenti
